Wish you could take your desktop workstation on the road with you? The HP ZBook 17 offers HP's ultimate in power plus portability with a 43,9 cm (17.3") diagonal screen, massive scalability and configurability, and all the latest power-packed features.
Product Description | HP ZBook 17 G3 Mobile Workstation - 17.3" - Intel Core i7 - 6700HQ - 8 GB RAM - 1 TB HDD - UK | Product Type | Mobile workstation | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English | Processor | Intel Core i7 (6th Gen) - 6700HQ / 2.6 GHz, up to 3.5 GHz / 6 MB Cache | Memory | 8 GB DDR4 (2 x 4 GB) | Storage | 1 TB HDD / 7200 rpm | Display | 17.3" LED backlight 1920 x 1080 / Full HD | Graphics | AMD FirePro W6150M / Intel HD Graphics 530 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, touchpad, pointing stick | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 6-cell | Dockable | Yes | Security | Trusted Platform Module (TPM) Security Chip, smart card reader | Colour | Graphite, hematite | Dimensions (WxDxH) | 42 cm x 28 cm x 3 cm | Weight | 3 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | HP Smart Buy | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6700HQ / 2.6 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM236 Express |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (2 x 4 GB) |
Max RAM Supported | 64 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 4 |
Empty Slots | 2 |
Storage | |
Main Storage | 1 TB HDD SATA 6Gb/s / 7200 rpm |
Display | |
Type | 17.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Features | Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) anti-glare, High Bit Rate 2 (HBR2) |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | AMD FirePro W6150M / Intel HD Graphics 530 |
Video System Features | NVIDIA Optimus, Shader Model 5.0 |
Camera | Yes - 1280 x 720 |
Camera Features | 720p HD movie recording, low light enhancement |
Sound | Stereo speakers, two microphones |
Codec | CX7501 |
Compliant Standards | High Definition Audio, DTS Studio Sound, DTS SOUND+ |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, touchpad, pointing stick |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Remote Management Protocol | SNMP 2 |
Features | Wake-on-LAN (WOL) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az |
Battery | |
Technology | 6-cell Lithium Ion |
Capacity | 96 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 200 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | VGA , HDMI , 2 x Thunderbolt 3 , Headphone/microphone combo jack , Battery , Dock , LAN , 4 x USB 3.0 |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software | |
Software Included | Drivers & Utilities, Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP SoftPaq Download Manager (free download), HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, Microsoft Internet Explorer 9.0, CyberLink YouCam BE, HP Wallpaper, HP Spare Key, Password Manager, Microsoft Internet Explorer 10, HP Peak Power Manager (free download), HP Client Security, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, HP Trust Circles Standard, Privacy Manager (free download), HP Disk Sanitizer, HP Ceement, HP Manageability, HP Wireless Button Driver, HP Validity Fingerprint Driver, HP Software Setup, HP Client Security Manager, HP 3D DriveGuard |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Dockable | Yes |
Features | HP DuraFinish, One-Step Logon, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, A-Tick, ICES, KC |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 3 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
