ITEM | QTY | PRICE |
StarTech.com 2m Laptop Power Cord - 3...
3 | £22.62 |
We built desktop workstation power, performance and expandability into a device designed for the road. Made for mobile creative and design professionals with the most demanding projects, where compromise is simply not an option.
Product Description | HP ZBook 15 G4 Mobile Workstation - 15.6" - Intel Core i7 - 7700HQ - 16 GB RAM - 256 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i7 (7th Gen) - 7700HQ / 2.8 GHz, up to 3.8 GHz / 6 MB Cache | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 256 GB SSD - HP Turbo Drive | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro M1200 / Intel HD Graphics 630 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Keyboard, touchpad, pointing stick | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 9-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip, smart card reader | Dimensions (WxDxH) | 38.6 cm x 26.4 cm x 2.6 cm | Weight | 2.6 kg | Localisation | Language: English / region: United Kingdom | Manufacturer Selling Program | HP Smart Buy | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7700HQ / 2.8 GHz |
Max Turbo Speed | 3.8 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel CM238 |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 64 GB |
Technology | DDR4 SDRAM - non-ECC |
Speed | 2400 MHz / PC4-19200 |
Rated Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 4 |
Empty Slots | 2 |
Storage | |
Main Storage | 256 GB SSD M.2 2280 PCIe - HP Turbo Drive |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 300 cd/m² |
Features | Full HD standard-viewing angle (SVA) eDP anti-glare |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA Quadro M1200 / Intel HD Graphics 630 |
Camera | Yes - 720p |
Video Resolutions | 1280 x 720 |
Frame Rate | 30 frames per second |
Sound | Stereo speakers, dual array microphone |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, touchpad, pointing stick |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, gesture function |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Remote Management Protocol | SNMP 2 |
Features | Miracast, Wake-on-LAN (WOL) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery | |
Technology | 9-cell lithium polymer |
Capacity | 90 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 150 Watt, 19.5 V |
Connections & Expansion | |
Interfaces Details | LAN , VGA , USB 3.0 (charging) , HDMI , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) , Headphone/microphone combo jack , 2 x USB 3.0 |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Miscellaneous | |
Features | HP 3D DriveGuard, HP DuraKeys, HP SpareKey, soft-touch surface, HP BIOS Protection, HP SureStart, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, FCC, RoHS, WEEE |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.6 kg |
Sustainability Information | |
TCO Certified | - |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
Get more from your purchase from one of our essential accessories
