Be productive in the office or in the field. Take advantage of the HP ZBook 15 G2's powerful processing and graphics, simple scalability, and blazing-fast connectivity to perform and collaborate at the speed of creativity.
Product Description | HP ZBook 15 G2 Mobile Workstation - 15.6" - Intel Core i7 - 4810MQ - 8 GB RAM - 256 GB SSD - UK | Product Type | Mobile workstation | Operating System | Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English | Processor | Intel Core i7 (4th Gen) - 4810MQ / 2.8 GHz, up to 3.8 GHz / 6 MB Cache | Memory | 8 GB DDR3L (2 x 4 GB) | Storage | 256 GB SSD - HP Z Turbo Drive | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | NVIDIA Quadro K2100M / Intel HD Graphics 4600 | Input Device | Keyboard, touchpad, pointing stick | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 8-cell | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader | Colour | Graphite, hematite | Dimensions (WxDxH) | 38.15 cm x 25.7 cm x 3.55 cm | Weight | 2.93 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - on-site , Limited warranty - battery - 3 years |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English |
Processor / Chipset | |
CPU | Intel Core i7 (4th Gen) 4810MQ / 2.8 GHz |
Max Turbo Speed | 3.8 GHz |
Number of Cores | Quad-Core |
Cache | L3 - 6 MB |
64-bit Computing | Yes |
Chipset | Intel QM87 |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (2 x 4 GB) |
Max RAM Supported | 32 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 4 |
Empty Slots | 2 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - HP Z Turbo Drive |
RAID Level | RAID 0, RAID 1 |
Optical Drive | DVD±RW (±R DL) / DVD-RAM removable - tray |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Features | Multi-Stream transport (MST), Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR, High Bit Rate 2 (HBR2) |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA Quadro K2100M / Intel HD Graphics 4600 |
Video System Features | NVIDIA Optimus, Shader Model 5.0 |
Camera | Yes - 1280 x 720 |
Sound | Stereo speakers, stereo microphone |
Codec | IDT 92HD91 |
Compliant Standards | High Definition Audio, DTS Studio Sound, DTS SOUND+ |
Input | |
Type | Keyboard, touchpad, pointing stick |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 7260 - PCI Express Half Mini Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I217-LM |
Remote Management Protocol | SNMP 2 |
Features | Wake-on-LAN (WOL) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.1as, IEEE 802.3az |
Battery | |
Technology | 8-cell Lithium Ion |
Installed Qty | 1 |
Max Supported Qty | 2 |
Capacity | 75 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 19.5 V |
Connections & Expansion | |
Expansion Bays | 1 x Upgrade Bay |
Slots | 1 x ExpressCard/54 (1 free) |
Interfaces | VGA , DisplayPort , Thunderbolt 2 , Headphone/microphone combo jack , Battery , Dock , LAN , 3 x USB 3.0 , USB 2.0 |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software | |
Software Included | Cyberlink PowerDVD, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP SoftPaq Download Manager (free download), HP ePrint, HP Hotkey Support, HP Performance Advisor, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Spare Key, HP Client Security, Device Access Manager with Just In Time Authentication, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, HP Disk Sanitizer, HP Manageability, HP Validity Fingerprint Driver |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Dockable | Yes |
Features | HP 3D DriveGuard, HP DuraFinish, HP SpareKey, One-Step Logon, HP DuraCase, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, A-Tick, ICES, KC |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.93 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site , Limited warranty - battery - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
