Everything you'd expect of the world's first workstation Ultrabook . HP's lightest mobile workstation – the new HP ZBook 14 utilizes impressive professional 3D graphics. This superbly thin, customizable workstation is light enough to carry when you're on the go – and powerful and reliable enough to carry you through the workday.
Product Description | HP ZBook 14 Mobile Workstation - 14" - Intel Core i7 - 4600U - vPro - 4 GB RAM - 750 GB HDD | Product Type | Mobile workstation | Operating System | Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence | Platform Technology | Intel vPro Platform | Processor | Intel Core i7 (4th Gen) - 4600U / 2.1 GHz, up to 3.3 GHz / 4 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 750 GB HDD / 7200 rpm + 32 GB SSD cache (M.2) | Display | 14" LED backlight Full HD UWVA eDP anti-glare+PSR 1920 x 1080 / Full HD | Graphics | AMD FirePro M4100 | Video Memory | 1 GB GDDR5 SDRAM | Input Device | Keyboard, touchpad, pointing stick | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet | Battery | 3-cell - up to 11 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader | Colour | Graphite, hematite | Dimensions (WxDxH) | 33.9 cm x 23.7 cm x 2.1 cm | Weight | 1.59 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years - carry-in , Limited warranty - battery - 3 years |
General | |
Recommended Use | Small business, corporate business |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence |
Processor / Chipset | |
CPU | Intel Core i7 (4th Gen) 4600U / 2.1 GHz |
Max Turbo Speed | 3.3 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Chipset | Intel QM87 |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 750 GB HDD SATA 3Gb/s / 7200 rpm |
SSD Cache | 32 GB (M.2) |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Colour Support | 1 billion colours |
Features | Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, Panel Self Refresh (PSR) |
Audio & Video | |
Graphics Processor | AMD FirePro M4100 |
Video System Features | AMD Dynamic Switchable Graphics |
Camera | Yes |
Video Resolutions | 1280 x 720 |
Camera Features | Low light enhancement |
Sound | Stereo speakers, stereo microphone |
Codec | IDT 92HD91 |
Compliant Standards | High Definition Audio, DTS Studio Sound |
Input | |
Type | Keyboard, touchpad, pointing stick |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n, Bluetooth 4.0 |
Wireless Controller | Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I218-LM |
Remote Management Protocol | SNMP 2 |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery | |
Technology | 3-cell lithium polymer |
Installed Qty | 1 |
Max Supported Qty | 2 |
Capacity | 50 Wh |
Run Time | Up to 11 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 18.5 V |
Connections & Expansion | |
Interfaces | 4 x USB 3.0 , DisplayPort , Headphone/microphone combo jack , LAN , Dock , VGA , Battery |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card) |
Software | |
Software Included | Cyberlink PowerDVD, CyberLink Power2Go, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Office (Trial), Microsoft Security Essentials, Computrace, HP Remote Graphics Software, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, HP Setup, HP Hotkey Support, PDF Complete Corporate Edition, HP Performance Advisor, Microsoft Internet Explorer 9.0, CyberLink YouCam BE, HP Wallpaper, Microsoft Internet Explorer 10, Device Access Manager, Privacy Manager, HP Wireless Hotspot (free download), HP Client Security, HP PageLift, HP Secure Erase, HP File Sanitizer, Box.net 50GB storage, Drive Encryption, HP Trust Circles Standard, HP Disk Sanitizer, HP Ceement, HP Manageability |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Dockable | Yes |
Features | Security lock slot (cable lock sold separately), HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP SpareKey, One-Step Logon, HP File Sanitizer, HP DuraCase, HP DisplaySafe, HP BIOS Protection, HP SureStart, 1 USB 3.0 (powered), SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, FIPS 140-2, KCC, WEEE, A-Tick, ICES |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.59 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - carry-in , Limited warranty - battery - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance | 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating) |
Vibration Tolerance | 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating) |
