HP's entry level workstations just got better. The HP Z240 with two amazingly versatile form factors, packs the performance, features, and reliability of a workstation into the price point of a desktop PC.
Powered to manage your challenges
Powerful processors, graphics, memory, and two optional ultra-fast HP Z Turbo Drives make the HP Z240 a true workstation-class solution. Handle your growing and complex workloads with performance for any stage in your work process.
Small price, big possibilities
The essential features of the HP Z240 Tower easily support your workload with slots and ports to spare. When you're ready for workstation class features, like professional ISV certifications, the HP Z240 Tower is the right first step.
Priced for your budget
HP's most affordable workstation allows you to customize your experience while still balancing your IT budget. HP reliability, thorough testing, and ISV certification means your HP Z240 is designed as a long-term budget friendly solution.
Choose the OS for you
Support your unique user needs with a choice of Windows 10 Pro or Linux® operating systems.
Better Package. Bigger Punch
Get more performance, expandability and flexibility in the chassis the world loves.
Powerful performance
Achieve the performance you need with your choice of next generation Intel® Xeon® processors or Intel® Core™ processors.
Ultra-fast storage
Handle large files, reduce work time and increase performance with the optional HP Z Turbo Drive.
Work smarter
Up to 64 GB DDR4 ECC memory helps provide no compromise capacity, performance, and reliability.
Geared up graphics
Ignite productivity with NVIDIA® professional graphics cards in 2D or 3D.
See the difference
Access AMD professional graphics including high-end 3D on Tower configurations.
Clean and cool
Help internal components stay clean and cool with a removable and cleanable dust filter.
Product Description | HP Workstation Z240 - MT - Core i7 6700 3.4 GHz - 16 GB - SSD 256 GB, HDD 1 TB - UK | Type | Workstation - mini tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (, up to 4 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 8 MB | Cache Per Processor | 8 MB | RAM | 16 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB - PCI Express 3.0 x4 - PCI Express - HP Turbo Drive G2 | Hard Drive (2nd) | HDD 1 TB - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD SuperMulti | Card Reader | Yes | Graphics Controller | PCIe 3.0 x16 - NVIDIA Quadro M2000 | Video Memory | 4 GB GDDR5 SDRAM | Networking | 1GbE | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence | Software Included | Windows 7 Professional 64-bit recovery DVD | Colour | Black | Dimensions (WxDxH) | 17 cm x 44.2 cm x 39.9 cm | Weight | 8.6 kg |
General | |
Type | Workstation |
Product Form Factor | Mini tower |
Embedded Security | Trusted Platform Module (TPM 1.2) Security Chip |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6700 |
Clock Speed | 3.4 GHz |
Max Turbo Speed | 4 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel C236 |
Cache Memory | |
Installed Size | 8 MB |
RAM | |
Installed Size | 16 GB / 64 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2133 MHz |
Memory Specification Compliance | PC4-17000 |
Form Factor | DIMM 288-pin |
Slots | 4 (Total) / 2 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 2 x 8 GB |
Hard Drive | |
Type | SSD - PCI Express |
Capacity | 1 x 256 GB |
Interface Type | PCI Express 3.0 x4 |
Features | HP Turbo Drive G2 |
Hard Drive (2nd) | |
Type | HDD |
Interface Class | Serial ATA |
Capacity | 1 x 1 TB |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Features | Native Command Queuing (NCQ) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 4 |
RAID Level | RAID 0, RAID 1 |
Optical Storage | |
Type | DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA |
Card Reader | |
Type | Card reader |
Supported Flash Memory Cards | SD Memory Card, SDHC Memory Card, SDXC Memory Card |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Interface Type | PCIe 3.0 x16 |
Graphics Processor | NVIDIA Quadro M2000 |
Video Interfaces | DVI, DisplayPort |
Max Monitors Supported | 4 |
Audio Output | |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Laser |
Interface | USB |
Networking | |
Ethernet Controller | Intel I219-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), PXE support |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az |
Expansion / Connectivity | |
Bays | 2 (total) / 2 (free) x external 5.25" x 1/2H , 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5" x 1/3H , 1 (total) / 1 (free) x internal 2.5" x 1/8H |
Slots | 1 (total) / 0 (free) x CPU , 4 (total) / 2 (free) x DIMM 288-pin , 1 (total) / 0 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x1 - full-length, full-height , 1 (total) / 0 (free) x PCIe 3.0 x16 - full-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height , 1 (total) / 1 (free) x M.2 Card (x4 mode) , 1 (total) / 0 (free) x M.2 Card (on PCI Express card) |
Interfaces | 6 x USB 3.0 (2 front, 4 rear) , 4 x USB 2.0 (2 front, 2 rear) (one of them is Always On) , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 2 x DisplayPort , 1 x DVI-I , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x microphone |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | RoHS, WEEE, ACPI 4.0 |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 400 Watt |
Efficiency | 92% |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English |
Software | Windows 7 Professional 64-bit recovery DVD |
Dimensions & Weight | |
Width | 17 cm |
Depth | 44.2 cm |
Height | 39.9 cm |
Weight | 8.6 kg |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 8 - 85% (non-condensing) |
