Get plenty of room to multi-task across your documents and e-mail and leave multiple windows open side by side with the HP V243 60.96 cm (24") LED Backlit Monitor, an extra-large display that's available at unbelievably low price point.
Product Description | HP v243 - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.276 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms (On/Off) | Colour Support | 16.7 million colours | Colour Gamut | 72% | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Screen Coating | Anti-glare | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 56.54 cm x 23.19 cm x 41.19 cm | Weight | 3.46 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, VCCI, BSMI, TUV S, CB, CCC, PSB, FCC, KCC, ICES, KC, CECP, CEL, EPA, ISC, SEPA | Manufacturer Warranty | 1-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Panel Type | TN |
Vertical Refresh Rate | 50 - 60 Hz |
Horizontal Refresh Rate | 24 - 80 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | WLED |
Colour Temperature | 6500K |
OSD Languages | Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Spanish, Dutch, Japanese |
Features | HDCP, Mercury free, arsenic-free glass |
Colour | Black |
Dimensions (WxDxH) | 56.54 cm x 23.19 cm x 41.19 cm - with stand |
Weight | 3.46 kg |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) |
Mechanical | |
Tilt Angle | -4/+22 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), detachable stand, VESA interface support |
Cables Included | 1 x VGA cable - 1.5 m |
Backlight Life | 30,000 hours |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 32 Watt |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 56.54 cm - depth: 5.65 cm - height: 33.99 cm - weight: 3.02 kg , With stand - width: 56.54 cm - depth: 23.19 cm - height: 41.19 cm - weight: 3.46 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
