HP t620 PLUS Flexible Thin Client AMD GX-415GA 4GB 16GB Windows Embedded Standard 7E 32-bit
free standard delivery
Key features
  • Customize your thin client with everything you need and nothing you don’t. Choose the configuration options and expansion capabilities that best fit your business and help ensure an ideal end user experience.
  • Configure your deployment to provide a powerful seamless desktop experience for your end users without exceeding your budget.
  • Help protect your thin client environment with integrated and optional hardware and software security solutions, including: HP BIOS implemented to NIST guidelines, a TPM chipset, Fiber NIC communications, and lockable covers and ports.
  • Reduce desktop service calls and product refreshes with a completely redesigned chassis that includes advanced passive cooling for fan-less support of quad-core processors.
Product codes
chevron icon
chevron icon
Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 PLUS Flexible Series Thin Client.
chevron icon
Product Description HP Flexible t620 PLUS - tower - GX-420CA 2 GHz - 4 GB - SSD 16 GB - TAA Compliant
Type Thin client - tower
Localisation Language: English / region: United Kingdom
Processor 1 x AMD GX-420CA 2 GHz (Quad-Core)
Cache Memory 2 MB L2 Cache
Cache Per Processor 2 MB
RAM 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800
Hard Drive SSD 16 GB - SATA
Optical Storage No optical drive
Graphics Controller AMD Radeon HD 8400E
Audio Output Stereo - integrated
Networking GigE, 802.11a, 802.11b/g/n
Power AC 120/230 V (50/60 Hz)
OS Provided Microsoft Windows Embedded Standard 7E 32-bit
Software Included Citrix ICA, Microsoft RDP, Microsoft Firewall, HP Universal Print Driver, HP ThinState Tools, Citrix XenDesktop Standard Edition, HP Connection Manager, Microsoft Windows Media Player 12, HP Easy Tools, File Based Write Filter, Enhanced Write Filter, HP Device Manager, Microsoft Internet Explorer 9.0, HP TeemTalk Terminal Emulator 7.3, LogOn Manager, Citrix HDX, Microsoft Remote Desktop Protocol (RDP) Client 8, HP Velocity, HP Remote Graphics Software 6, Microsoft RemoteFX, Citrix Receiver 4.0, HP Cloud Connection Manager, VMware Horizon View 5.4
Dimensions (WxDxH) 6.5 cm x 22 cm x 24 cm
Weight 2.04 kg
TAA Compliant Yes
Environmental Standards ENERGY STAR Qualified EPEAT Gold
Manufacturer Warranty Limited warranty - 3 years
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
