Get a powerful and seamless desktop experience, enhanced security features, and premium client virtualization from the HP t620 Flexible Series Thin Client.
Product Description | HP Flexible t620 - tower - GX-415GA 1.5 GHz - 4 GB - SSD 16 GB - TAA Compliant | Type | Thin client - tower | Localisation | Language: English / region: United Kingdom | Processor | 1 x AMD GX-415GA 1.5 GHz (Quad-Core) | Cache Memory | 2 MB L2 Cache | Cache Per Processor | 2 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR3L SDRAM - PC3-12800 | Hard Drive | SSD 16 GB - SATA - mSATA | Optical Storage | No optical drive | Graphics Controller | AMD Radeon HD 8330E | Audio Output | Stereo - integrated | Networking | 1GbE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows Embedded 8 Standard x64 Edition | Dimensions (WxDxH) | 4 cm x 22 cm x 24 cm | Weight | 1.36 kg | Manufacturer Selling Program | HP Top Value | TAA Compliant | Yes | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Type | Thin client |
Recommended Use | Small business, corporate business |
Product Form Factor | Tower |
Processor / Chipset | |
CPU | AMD GX-415GA |
Clock Speed | 1.5 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | L2 Cache - 2 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR3L SDRAM |
Effective Memory Speed | 1600 MHz |
Rated Memory Speed | 1600 MHz |
Memory Specification Compliance | PC3-12800 |
Form Factor | SO-DIMM 204-pin |
Slots | 2 (Total) / 1 (empty) |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | SSD - mSATA |
Capacity | 1 x 16 GB |
Interface Type | SATA |
Features | Multi-level cell (MLC) |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Type | Integrated |
Graphics Processor | AMD Radeon HD 8330E |
Video Interfaces | VGA, DisplayPort |
Audio Output | |
Type | Integrated |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Standard Keyboard |
Interface | USB |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Type | Integrated |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Features | Wake on LAN (WoL), DHCP support, PXE support |
Expansion / Connectivity | |
Slots | 1 (total) / 0 (free) x mSATA , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCIe Mini Card , 1 (total) / 1 (free) x M.2 Card |
Interfaces | 6 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 (2 in front) , 2 x DisplayPort , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x VGA |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | FCC Class B certified, TUV GS, VCCI, UL 1950, CSA 22.2 No. 950, EN55022 Class B, RoHS, WEEE |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Operating System / Software | |
OS Certified | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Citrix Presentation Server 4.0, Citrix XenDesktop 3.0, Citrix XenApp 5, Microsoft Windows Server 2012 |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Dimensions & Weight | |
Width | 4 cm |
Depth | 22 cm |
Height | 24 cm |
Weight | 1.36 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
