Give your office powerful scan speed and accuracy. Built-in software and an 80-page automatic document feeder help you save time. Scan at up to 50 ppm/100 ipm. Recommended for 6,000 pages per day.
Fast, smooth scanning – even unattended
Capture entire documents with one-pass duplex scanning up to 50 ppm/100 ipm.
Peak workflow performance. Smarter scanning.
Identify new devices and gain insight into scanning with HP Web Jetadmin remote discovery and monitoring.
Professional-grade scanning that helps save time
Save time and simplify complex scan jobs with HP Smart Document Scan Software.
Product Description | HP ScanJet Enterprise Flow 5000 s4 Sheet-feed Scanner - document scanner - desktop - USB 3.0, USB 2.0 | Device Type | Document scanner - desktop | Interface Type | USB 3.0, USB 2.0 | Scanning Sensor Type | Contact Image Sensor (CIS) | Additional Functions | Max Supported Document Size | 215.9 x 3098.8 mm | Localisation | English, German, French, Italian, Spanish / Europe | Input Type | Colour | Grayscale / Color Depth | 48-bit colour | Grayscale / Color Depth (External) | 24-bit (16.7 million colours) | Optical Resolution | 600 dpi x 600 dpi | Max Document Scan Speed | 55 ppm (mono) / 45 ppm (colour) | Max Document Size | 215.9 mm x 3098.8 mm | Automatic Duplexing | Yes | Document Feeder Type | Automatic | Document Storage Capacity | 80 sheets | Duty Cycle | 6000 scans per day | Environmental Standards | ENERGY STAR Qualified |
General | |
Additional Functions | |
Scanner | |
Colour Depth | 48-bit colour |
Colour Depth (External) | 24-bit (16.7 million colours) |
Scan Mode | Single-pass |
Max Document Scan Speed B/W | 55 ppm |
Max Document Scan Speed Colour | 45 ppm |
Scanner Speed Details | 55 ppm - black & white - 300 dpi , 45 ppm - colour - 300 dpi , 110 ipm - duplex - black & white - 300 dpi , 90 ipm - duplex - colour - 300 dpi , 5.18 sec/scan - photo - colour - 10x15cm - 200 dpi , 4.98 sec/scan - photo - colour - 10x15cm - 150 dpi , 6.63 sec/scan - colour - A4 - 300 dpi |
Scanner Features | Ultrasonic Multi Feed Detection, HP EveryPage |
Scan File Formats | BMP, JPEG, PNG, TIFF |
Compliant Standards | TWAIN, ISIS, WIA |
Media Handling | |
Supported Document Size Details | ADF - up to 215.9 x 3098.8 mm |
Expansion / Connectivity | |
Interfaces Details | USB 3.0 , USB 2.0 |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Software / System Requirements | |
Software Included | Readiris Pro, Cardiris, Nuance PaperPort, HP Smart Document Scan Software, HP Scanner Tools Utility |
Dimensions & Weight (Shipping) | |
Shipping Width | 39.7 cm |
Shipping Depth | 30.3 cm |
Shipping Height | 24.8 cm |
Shipping Weight | 5.4 kg |
