Mobility without compromise. Maximize productivity with the convenience of a tablet and the power of a notebook. Work confidently in or out of the office with commercial grade security and connectivity.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | HP Pro x2 612 G1 - 12.5" - Intel Core i3 - 4012Y - 4 GB RAM - 128 GB SSD | Product Type | Tablet - with keyboard dock | Operating System | Win 8.1 Pro 64-bit | Processor | Intel Core i3 (4th Gen) - 4012Y / 1.5 GHz / 3 MB Cache | Memory | 4 GB DDR3L (provided memory is soldered) | Storage | 128 GB SSD | Display | 12.5" LED backlight touchscreen 1366 x 768 / HD | Graphics | Intel HD Graphics 4200 | Input Device | Keyboard, touchpad | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet | Features | Ambient light sensor | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) - tablet | 30.7 cm x 20.95 cm x 1.28 cm | Weight | 925.7 g | Localisation | Language: English / region: United Kingdom | Manufacturer Warranty | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
General | |
Operating System | Windows 8.1 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i3 (4th Gen) 4012Y / 1.5 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Storage | |
Main Storage | 128 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 12.5" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Brightness | 300 cd/m² |
Features | Ultra Slim Design, Corning Gorilla glass 3, HD ultra wide-viewing angle (UWVA) eDP anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 4200 |
Camera | Yes - Full HD |
Resolution | 5 Megapixel (rear), 2 Megapixel (front) |
Camera Features | 1080p Full HD movie recording, low light enhancement |
Sound | Stereo speakers, two microphones |
Codec | Realtek ALC3228 |
Compliant Standards | High Definition Audio, DTS SOUND+ |
Input | |
Type | Keyboard, touchpad |
Features | Volume control, spill-resistant |
Communications | |
Wireless | 802.11a/b/g/n, Bluetooth 4.0 |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-N 7260AN - PCI Express Half Mini Card |
Network Interface | Gigabit Ethernet |
Compliant Standards | IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | Lithium polymer |
Installed Qty | 2 |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Interfaces | USB 3.0 , Headphone/microphone combo jack , 2 x USB 3.0 (on keyboard dock) , DisplayPort (on keyboard dock) , VGA (on keyboard dock) , Headphone/microphone combo jack (on keyboard dock) , Dock (on keyboard dock) , LAN (on keyboard dock) |
Memory Card Reader | Yes (SD Card, SDHC Card, microSD, SDXC Card, microSDHC, microSDXC) |
Software | |
Software Included | Cyberlink PowerDVD, Skype, HP Support Assistant, HP ePrint, HP Hotkey Support, Netflix, Foxit PhantomPDF Express, Absolute Data Protection (90 days trial), HP Spare Key, Microsoft Internet Explorer 10, Windows Defender, HP Client Security, Device Access Manager with Just In Time Authentication, HP PageLift, HP File Sanitizer, Microsoft Internet Explorer 11, Drive Encryption, HP Manageability, Box.net |
Miscellaneous | |
Integrated Options | Ambient light sensor |
Dockable | Yes |
Features | Microphone with echo and noise-cancellation, HP SureStart, Full Volume Encryption, 1 USB 3.0 charging port |
Included Accessories | Power adapter |
Compliant Standards | RoHS, WEEE |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 925.7 g |
Dimensions (WxDxH) / Weight Details | 31.7 cm x 23.95 cm x 2.33 cm - tablet with keyboard |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
