Powered for business, the HP ProDesk 600 is a highly expandable PC featuring flexible connectivity, strong security, and comprehensive manageability features in a stylishly redesigned chassis for the modern workplace.
Product Description | HP ProDesk 600 G3 - mini desktop - Core i5 7500T 2.7 GHz - 8 GB - SSD 256 GB - UK | Type | Personal computer - mini desktop | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (7th Gen) 7500T / 2.7 GHz (, up to 3.3 GHz, (Quad-Core) | Processor Main Features | Intel Turbo Boost Technology 2, Intel Smart Cache | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-19200 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB - PCI Express - M.2 2280 - NVM Express (NVMe), triple-level cell (TLC) | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics 630 | Audio Output | Stereo | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2 | Keyboard | UK | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 17.7 cm x 17.47 cm x 3.42 cm | Weight | 1.21 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years - on-site |
General | |
Type | Personal computer |
Product Form Factor | Mini desktop |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7500T |
Clock Speed | 2.7 GHz |
Max Turbo Speed | 3.3 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | Intel Q270 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Memory Specification Compliance | PC4-19200 |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD - M.2 2280 |
Capacity | 1 x 256 GB |
Interface Type | PCI Express |
Features | NVM Express (NVMe), triple-level cell (TLC) |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | VGA, DisplayPort |
HDCP Compatible | Yes |
Max Monitors Supported | 3 |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Keyboard Name | HP Business Slim Keyboard |
Interface | USB |
Localization & Layout | UK |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Interface (Bus) Type | PCI Express Mini Card (M.2) |
Ethernet Controller | Intel I219-LM |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 8265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.11, IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" |
Slots | 1 (total) / 0 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 0 (free) x M.2 Card - 2280 (x4 mode) |
Interfaces | 6 x USB 3.1 Gen 1 (2 front, 4 rear) (two of them with wake functionality, one of them is fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 2 x DisplayPort , 1 x VGA , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), padlock loop |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | 100 x 100 mm |
Compliant Standards | ACPI, CCC, CECP, SEPA |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 65 Watt |
Efficiency | 89% (115VAC), 89% (230VAC) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years - on-site |
Dimensions & Weight | |
Width | 17.7 cm |
Depth | 17.47 cm |
Height | 3.42 cm |
Weight | 1.21 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
