Work seamlessly with the HP Pro Slate 8, a full HD tablet which runs Android Lollipop with native Work Profiles, a feature of Android for Work, and has hardware-enabled security, a Qualcomm Snapdragon 800 series processor, and an HP Duet Pen.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | HP Pro Slate 8 - tablet - Android 4.4.4 (KitKat) - 16 GB - 7.86" | Product Type | Tablet | Operating System | Android 4.4.4 (KitKat) - English | Display | 7.86" IPS - 2048 x 1536 (326 ppi) - Multi-Touch | Processor | Qualcomm Snapdragon 800 (Quad-Core) | Processor Clock Speed | 2.3 GHz | Storage | 16 GB eMMC | RAM | 2 GB | Supported Flash Memory Cards | microSD | Wireless Connectivity | Bluetooth 4.0, 802.11a/b/g/n/ac, NFC | Rear Camera | 8 Megapixel focus: automatic | Front Camera | 2 Megapixel | Navigation System | GPS | Battery Run Time | Up to 13.75 hours | Dimensions (WxDxH) | 13.695 cm x 0.799 cm x 20.699 cm | Weight | 350 g | Colour | Grey | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Display | |
Type | 7.86" IPS |
Resolution | 2048 x 1536 (326 ppi) |
Touchscreen | Multi-Touch |
Image Aspect Ratio | 4:3 |
Features | 10-point multi-touch, Direct Bonding technology, Corning Gorilla glass 4, Wide Viewing Angle |
Processor | |
Processor | Qualcomm Snapdragon 800 |
Number of Cores | Quad-Core |
Memory | |
RAM | 2 GB - LPDDR3 SDRAM |
Max Supported Capacity | 32 GB |
Communications | |
Security Protocols & Features | Wi-Fi Miracast, Android Beam |
Rear Camera | |
Sensor Resolution | 8 Megapixel |
Focus Adjustment | Automatic |
HDR Mode | Auto HDR mode |
Front Camera | |
Sensor Resolution | 2 Megapixel |
Navigation System | |
Receiver | GPS |
Multimedia | |
Audio | Two microphones, stereo speakers |
Software | |
Preloaded Software | Skype, Evernote, Secure Boot, Kingsoft Office, Corel Painter Mobile, HP Print, Avast Mobile Security, HP TouchPoint Manager, HP Notes, HP Duet Pen Software |
Expansion and Connectivity | |
Expansion Slots | 1 x microSD |
Interfaces | 1 x headset mini jack (3.5mm) , 1 x Micro-USB , 1 x HDMI (supporting via optional adapter) |
Battery | |
Technology | Lithium polymer |
Capacity | 21 Wh |
Run Time Details | Video playback: up to 13.75 hours |
Miscellaneous | |
Colour | Grey |
Sensors | Accelerometer, ambient light sensor, proximity sensor, digital compass, barometer, gyro sensor, hall sensor |
Features | Capacitive touch screen, UV protection, soft-touch surface, Data-at-Rest Encryption, SecureBoot, smudge-resistant, ARM TrustZone, DTS Sound+, TrustZone-based Key Store, 256-bit hardware acceleration |
Included Accessories | Power adapter, stylus |
Cables Included | Micro-USB to USB cable |
Compliant Standards | CSA, UL, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, RSS-102, EMC, IC, FCC, FIPS 140-2, FCC CFR47 Part 15, EN 60950-1, EN 301 908, EN 62311, EN 300.440, EN 300 328, EN 301 489, FCC CFR47 Part 2, EN 301 893 |
Dimensions & Weight | |
Width | 13.695 cm |
Depth | 0.799 cm |
Height | 20.699 cm |
Weight | 350 g |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Limited warranty - battery - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 60 °C |
