Help your business stand out with stunning, wide-format colour prints at a price that you can afford. Accelerate productivity and keep business moving with a wide range of tools. Create professional-quality marketing materials – right in the office.
Product Description | HP Officejet 7510 Wide Format All-in-One - multifunction printer - colour | Device Type | Multifunction printer | Fax Type | Plain paper | Localisation | EMEA (excluding Israel, Saudi Arabia, South Africa) | Printing Technology | Ink-jet (colour) | Inkjet Technology | HP Thermal Inkjet - 4-ink | Monthly Duty Cycle (max) | 12000 pages | Recommended Monthly Volume | 200 - 800 pages | Max Copying Speed | Up to 9 ppm (mono) / up to 6 ppm (colour) | Max Copying Resolution | Up to 600 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Printing Speed | Up to 15 ppm (mono) / up to 8 ppm (colour) | Max Printing Resolution | Up to 600 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour) | Max Fax Transmission Speed | 33.6 Kbps | Fax Resolutions | 203 x 98 dpi, 203 x 196 dpi | Scanning | 1200 dpi | Display | 2.65" | Original Size | 127 x 178 mm (min) - Legal (216 x 356 mm) (max) | Original Type | Sheets | Document Feeder Capacity | 35 sheets | Media Size | A3 (297 x 420 mm) (max) | Media Type | Plain paper, photo paper, thick paper, glossy paper, matte paper | Standard Media Capacity | 250 sheets | Output Trays Capacity | 75 sheets | Connection Availability | Yes | Interface | USB 2.0, LAN, Wi-Fi(n), USB host | AirPrint Enabled | Yes | Office Machine Features | Save to USB flash drive, scan to e-mail, scan to folder, automatic paper sensor | Power | AC 120/230 V (50/60Hz) | Dimensions (WxDxH) | 61.3 cm x 48.3 cm x 36.6 cm | Weight | 13.02 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Printing Technology | Ink-jet - colour |
Display Diagonal Size | 2.65" |
Display Features | Touch screen |
Memory | |
Standard Memory | 256 MB |
Max Supported Memory | 256 MB |
Copying | |
Max Document Enlargement | 400% |
Max Document Reduction | 25% |
Maximum Copies | 99 |
Printing | |
Inkjet Technology | HP Thermal Inkjet |
Ink Cartridge Configuration | 4 cartridges (1 each: cyan, magenta, yellow, black) |
Ink Palette Supported (Colours) | Cyan, magenta, yellow, black |
Colour | 4-ink |
Printer Drivers / Emulations | PCL 3e, PCL 3 GUI |
Scanning | |
Optical Resolution | 1200 dpi |
Grayscale Depth | 8-bit |
Colour Depth | 24-bit |
Fax Machine | |
Max Transmission Speed | 33.6 Kbps |
Total Memory Capacity | Up to 100 pages |
Fax Machine Features | |
Speed Dialing | 100 station(s) |
Broadcast Transmission | 48 stations |
Features | Colour faxing |
Document & Media Handling | |
Min Original Size | 127 x 178 mm |
Max Original Size | Legal (216 x 356 mm) |
Min Media Weight | 34 g/m² |
Max Media Weight | 250 g/m² |
Supported Media Type | Plain paper, photo paper, thick paper, glossy paper, matte paper |
Supported Media Sizes | A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 130 x 180 mm, 90 x 130 mm, JIS B5 (182 x 257 mm), JIS B4 (257 x 364 mm) |
Supported Envelope Sizes | US A2 (111 x 146 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm) |
Borderless Photo Sizes | A3 Plus (305 x 457 mm) |
Document & Media Handling Details | ADF - 35 sheets size: 127 x 178 mm - Legal (216 x 356 mm) , Input tray - 250 sheets - A3 (297 x 420 mm) weight: 34 g/m² - 250 g/m² , Output tray - 75 sheets |
Speed Details | Printing: up to 15 ppm - B/W (ISO) , Printing: up to 8 ppm - colour (ISO) , Copying: up to 33 ppm (A4) - B/W draft , Copying: up to 29 ppm (A4) - colour draft , Printing: up to 33 ppm (A4) - B/W draft , Printing: up to 29 ppm (A4) - colour draft , Copying: up to 9 ppm - B/W (ISO) , Copying: up to 6 ppm - colour (ISO) , Printing: up to 33 ppm (Letter A) - B/W draft , Printing: up to 29 ppm (Letter A) - colour draft |
Connections | |
Interfaces | 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x modem - RJ-11 |
Operating System Support | Linux, Apple Mac OS X 10.8, Apple Mac OS X 10.9, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits) |
Software Included | Drivers & Utilities, HP Photo Creations |
Power | |
Voltage Required | AC 120/230 V (50/60Hz) |
Power Consumption Operational | 27.7 Watt |
Power Consumption Standby | 4.57 Watt |
Power Consumption Sleep | 1.89 Watt |
Miscellaneous | |
Compliant Standards | EN 61000-3-2:2006, EN 61000-3-3:2008, EN 55024:2010, CISPR 22:2008, EN 55022:2010 Class B |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 61.3 cm |
Depth | 48.3 cm |
Height | 36.6 cm |
Weight | 13.02 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 16.55 kg |
Environmental Parameters | |
Sound Emission | 57 dBA (operating) |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 20 - 80% |
