Enjoy the thin, light, and cost effective HP EliteBook 745. Be ultra-productive by staying connected with impressive collaboration and connectivity features for your growing business on the HP EliteBook 745.
Slim new design with all the right ports
Connect with all of the essential ports you need without the hassle of dongles - in a thin and light design. At just 18.9 mm, the HP EliteBook 745 comes with VGA, Display Port, RJ-45 and enterprise docking capabilities.
Strong security, powerful manageability
Protect, detect, and recover from malicious attacks with HP Sure Start - the industry’s first self-healing BIOS. Keep your team up and running with HP Touchpoint Manager and DASH manageability to help monitor the HP EliteBook 745.
Designed for collaboration
Replace your speaker phone with the HP EliteBook 745 with Audio by Bang & Olufsen that provides a rich collaboration experience for applications like Skype for Business.
Great features and value, from HP!
The ultrathin HP EliteBook 745 delivers tremendous value. HP is the first to offer the new high-performance AMD PRO A12 APU, the first commercial APU with integrated Radeon™ R7 graphics that help harness the full potential of your applications.
Key Features
Let nothing stand in your way
Power through your day with Windows 10 Pro and the powerful, sleek, thin, and light touch optional HP EliteBook 745.
Self-healing safeguard
HP Sure Start detects attacks, corruption and self-heals the BIOS automatically.
Give your fingers a break
Keep focused without the distraction of a noisy keyboard using the HP Premium Keyboard engineered for comfort.
Field ready
Stand up to the workload with an EliteBook that passed MIL-SPEC 810G testing.
In-house serviceability
Easily expand your system’s serviceable components.
Give your speakers a boost
Help make good speakers sound great with HP Clear Sound Amp.
Cut out the chatter
Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software.
AMD Vivid Color Technology
Experience the brilliant color saturation that makes images come to life with AMD Vivid Color Technology.
Product Description | HP EliteBook 745 G3 Notebook - 14" - AMD A8 - PRO-8600B - 8 GB RAM - 128 GB SSD - UK | Product Type | Notebook | Operating System | Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English | Processor | AMD A8 PRO-8600B / 1.6 GHz, up to 3 GHz / 2 MB Cache | Memory | 8 GB DDR3L (1 x 8 GB) | Storage | 128 GB SSD | Display | 14" LED backlight 1920 x 1080 / Full HD | Graphics | AMD Radeon R6 | Input Device | Pointing stick | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 3-cell | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 33.8 cm x 23.7 cm x 1.89 cm | Weight | 1.54 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English |
Processor / Chipset | |
CPU | AMD A8 PRO-8600B / 1.6 GHz |
Max Turbo Speed | 3 GHz |
Number of Cores | Quad-Core |
Cache | 2 MB |
64-bit Computing | Yes |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz / PC3L-12800 |
Rated Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 128 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 14" - TN |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Brightness | 300 cd/m² |
Features | Vivid Color, Slim Design, Full HD standard-viewing angle (SVA) eDP anti-glare |
Audio & Video | |
Graphics Processor | AMD Radeon R6 |
Camera | Yes - 1280 x 720 |
Sound | Stereo speakers, two microphones |
Codec | ALC3228 |
Compliant Standards | DTS Studio Sound, DTS SOUND+ |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, touchpad, pointing stick |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Broadcom BCM5762 |
Remote Management Protocol | SNMP 2 |
Features | Miracast |
Compliant Standards | IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 3-cell lithium polymer |
Installed Qty | 1 |
Capacity | 46 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Slots | 1 x Micro-SIM card (1 free) |
Interfaces Details | 2 x USB 3.0 , USB-C , DisplayPort , VGA , Headphone/microphone combo jack , LAN , Dock |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Software | |
Software Included | Cyberlink PowerDVD, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Pixel Sharp, HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Dockable | Yes |
Features | HP DuraKeys, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, 1 USB 3.0 charging port, Pre-boot Authentication |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.54 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years |
