More than a tablet-a total business solution. The elegant and sleek HP ElitePad 1000 G2 has the performance and flexibility to transform the way you work. Redefine productivity and stay light with the confidence of the leading manageability, security, and support you expect from HP.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | HP ElitePad 1000 G2 - 10.1" - Intel Atom - Z3795 - 4 GB RAM - 128 GB eMMC - 3G | Product Type | Tablet - no keyboard | Operating System | Win 8.1 Pro 64-bit | Processor | Intel Atom Z3795 / 1.59 GHz, up to 2.39 GHz / 2 MB Cache | Memory | 4 GB LPDDR3 | Storage | 128 GB eMMC | Display | 10.1" LED backlight touchscreen 1920 x 1200 / WUXGA | Graphics | Intel HD Graphics | Input Device | Digitizer | Integrated Webcam | Yes | Networking | 802.11a/b/g/n, Bluetooth 4.0 | Wireless Broadband (WWAN) | 3G | Service Provider | Service not included | Battery | 2-cell | Features | Ambient light sensor | Dockable | Yes | Security | Trusted Platform Module (TPM 1.2) Security Chip | Dimensions (WxDxH) | 26.1 cm x 17.8 cm x 0.92 cm | Weight | 680 g | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
General | |
Recommended Use | Small business, corporate business |
Operating System | Windows 8.1 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Atom Z3795 / 1.59 GHz |
Max Turbo Speed | 2.39 GHz |
Number of Cores | Quad-Core |
Cache | L2 - 2 MB |
Features | Intel Burst Technology |
Memory | |
RAM | 4 GB |
Technology | LPDDR3 SDRAM |
Speed | 1067 MHz |
Storage | |
Main Storage | 128 GB eMMC |
Display | |
Type | 10.1" |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (multi-touch) |
Resolution | 1920 x 1200 (WUXGA) |
Widescreen | Yes |
Image Aspect Ratio | 16:10 |
Features | Anti-smudge, Corning Gorilla glass 3 |
Audio & Video | |
Graphics Processor | Intel HD Graphics |
Camera | Yes |
Resolution | 8 Megapixel (rear), 2.1 Megapixel (front) |
Video Resolutions | 1920 x 1080 |
Camera Features | LED flash |
Sound | Stereo speakers, stereo microphone |
Compliant Standards | DTS SOUND+ |
Input | |
Type | Digitizer |
Communications | |
Wireless | 802.11a/b/g/n, Bluetooth 4.0 |
Bluetooth Class | Class 2 |
Wireless Controller | Broadcom BCM43241 |
Features | Gobi Technology |
Compliant Standards | Wi-Fi CERTIFIED |
Wireless Broadband (WWAN) | |
Generation | 3G |
Technology | GPRS, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, WCDMA, DC-HSPA+ |
Controller | HP hs3110 - M.2 Card |
Max Transfer Rate | 21.6 Mbps |
Battery | |
Technology | 2-cell lithium polymer |
Capacity | 30 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 10 Watt |
Connections & Expansion | |
Interfaces | Headphone/microphone combo jack , Dock |
Memory Card Reader | Yes (microSDXC) |
Software | |
Software Included | HP SoftPaq Download Manager, HP Support Assistant, HP ePrint, HP Setup, PDF Complete Corporate Edition, Absolute Data Protect, Netflix, HP Wallpaper, Amazon Kindle, HP Registration, HP Client Security, HP Mobile Connect, Device Access Manager with Just In Time Authentication, HP PageLift, Box.net 50GB storage, Drive Encryption, HP Trust Circles Standard, HP Manageability, HP Wireless Hotspot |
Miscellaneous | |
Case Material | Aluminum |
Integrated Options | Ambient light sensor |
Dockable | Yes |
Features | Digital compass, Accelerometer, gyroscope, Haptics |
Included Accessories | Power adapter, HP ElitePad USB Adapter |
Compliant Standards | CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, WEEE, A-Tick, ICES, KC |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 680 g |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance | 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating) |
Vibration Tolerance | 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating) |
