Elegant, sleek, user-friendly, and designed to perform, the HP EliteOne 800 is ready to deploy in demanding environments, with manageability and security, enterprise-class collaboration technologies, and touchscreen configurations.
Place it here, there, and everywhere
Deploy this redesigned, stylish All-in-One with a 58.4 cm (23") diagonal FHD display anywhere you need a powerhouse PC. Its slim design and integrated cable management make an impression at reception, on an executive’s desk or mounted on a wall.
Deeply secure
Help secure your PC with comprehensive hardware and software tools like an optional fingerprint reader and HP BIOSphere with Sure Start’s customizable BIOS-level passwords.
Power-packed performance
Drive your most demanding workloads with an All-in-One powered by fast 6th Gen Intel® Core™ processors, plus AMD Radeon™ R9 360 discrete graphics with 2 GB GDDR5 for your most challenging use cases.
Count on premier audiovisual clarity
Collaborate naturally with Cortana on Windows 10 Pro, optional 10-point capacitive touch, Audio by Bang & Olufsen, HP Clear Sound Amp, HP Noise Reduction Software, and a 2MP HD webcam.
Featuring
Let nothing stand in your way
Help protect from today’s security threats and maximize management and productivity features for business with Window 10 Pro.
Ready to run, and upgrade
Make expansion and upgrades a snap with a tool-less rear access panel.
World-class management
Simplify IT manageability with Intel® vPro™8 and Windows 101 plus HP Common Core BIOS, which enables easy management of your entire fleet of HP devices.
Tested to go the distance
Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G9 testing.
Consistently stagger deployments
Get the same HP configuration across the globe, available in more than 180 countries where HP conducts business.
Make your workspace more workable
Make more room with optional, versatile stands or a space-saving VESA wall mount10 for a range of use cases.
Fast easy login
Save time and help eliminate the need for cumbersome complicated passwords by using the integrated fingerprint reader.
Windows 10 Pro 64
Product Description | HP EliteOne 800 G2 - all-in-one - Core i5 6500 3.2 GHz - vPro - 8 GB - Hybrid Drive 1 TB - LED 23" | Type | Personal computer - all-in-one - administrator password, power-on password, hard drive I/O control, USB port control, adjustable height, Intel Identity Protection Technology (Intel IPT), HP BIOS Protection, Setup Password, UEFI BIOS, HP DriveLock, Master Record Security, Power On Authentication, 1 USB 3.0 fast charging port, 1 USB-C fast charging port | Platform Technology | Intel vPro Platform | Localisation | Language: English / region: United Kingdom | Processor | Intel Core i5 (6th Gen) 6500 / 3.2 GHz (3.6 GHz) (Quad-Core) | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000 | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | Hybrid Drive 1 TB (8 GB cache) - SATA 6Gb/s - 7200 rpm | Optical Storage | DVD SuperMulti | Monitor | 23" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen | Graphics Controller | Intel HD Graphics 530 Dynamic Video Memory Technology | Audio Output | Stereo | Networking | GigE, 802.11a, 802.11b/g/n, Bluetooth 4.0 | Power | AC 120/230 V (50/60 Hz) | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 56.72 cm x 28 cm x 43.5 cm | Weight | 10.76 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Type | Personal computer |
Product Form Factor | All-in-one |
Embedded Security | Trusted Platform Module (TPM 1.2) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6500 |
Clock Speed | 3.2 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Upgradability | Upgradable |
Chipset Type | Intel Q170 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM - non-ECC |
Effective Memory Speed | 2133 MHz |
Rated Memory Speed | 2133 MHz |
Memory Specification Compliance | PC4-17000 |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | Hybrid Drive |
Capacity | 1 x 1 TB (8 GB cache) |
Interface Type | SATA 6Gb/s |
Spindle Speed | 7200 rpm |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | DVD±RW (±R DL) / DVD-RAM DVD SuperMulti - SATA |
Monitor | |
Monitor Type | LED - IPS |
Touchscreen | Yes (10-point multi-touch) |
Diagonal Size | 23" |
Native Resolution | 1920 x 1080 (Full HD) |
Widescreen Display | Yes |
Image Aspect Ratio | 16:9 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Colour Gamut | 72% |
Pixel Pitch | 0.265 mm |
Image Brightness | 225 cd/m² |
Image Contrast Ratio | 1000:1 |
Monitor Features | Projected Capacitive Touch (PCT) technology |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 530 Dynamic Video Memory Technology |
Video Interfaces | DisplayPort |
HDCP Compatible | Yes |
Max Monitors Supported | 3 |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 192 kHz |
Compliant Standards | High Definition Audio |
Speakers Included | 2 x right / left channel |
Input Device | |
Type | Mouse |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Intel I219-LM |
Wireless LAN Supported | Yes |
Wireless NIC | Broadcom BCM943228Z |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0 |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.3az, Bluetooth 4.0 |
Expansion / Connectivity | |
Bays | 1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 2.5" |
Slots | 1 (total) / 0 (free) x CPU , 1 (total) / 0 (free) x M.2 Card (x1 mode) , 2 (total) / 1 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card (x4 mode) |
Interfaces | 6 x USB 3.0 , 1 x DisplayPort , 1 x audio line-in/headphones/microphone , 1 x audio line-out/headphones , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) , 1 x USB-C 3.0 |
Miscellaneous | |
Features | Administrator password, power-on password, hard drive I/O control, USB port control, adjustable height, Intel Identity Protection Technology (Intel IPT), HP BIOS Protection, Setup Password, UEFI BIOS, HP DriveLock, Master Record Security, Power On Authentication, 1 USB 3.0 fast charging port, 1 USB-C fast charging port |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | 100 x 100 mm |
Compliant Standards | ACPI, CCC, CECP, SEPA |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Factor Correction | Yes (active) |
Operating System / Software | |
OS Provided | Windows 10 Pro 64-bit Edition English |
Software | CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Windows Defender, HP Secure Erase, HP Client Security Manager |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 56.72 cm |
Depth | 28 cm |
Height | 43.5 cm |
Weight | 10.76 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
