Exquisite craftsmanship and exceptional performance are united in the HP EliteBook Folio. With hand-selected materials and premium features optimized for collaboration, it's the choice for those who value a flawless experience.
Elevating durable design
Cutting-edge design, innovative engineering, and refined materials come together in the sophisticated and durable HP EliteBook Folio. Confidently take on the workday with this elegant PC that passed MIL-STD 810G testing.
Premium collaboration
Engage teams, clients, and vendors with the crystal-clear audio by Bang & Olufsen and the high-performance HP Premium Collaboration Keyboard that allows you to launch calls and video chats at the touch of a button on the HP EliteBook Folio.
Leave passwords behind
Use the IR camera with Windows Hello to use your face as your password to unlock a Windows 10 Pro[1] device or browse the web.
Product Description | HP EliteBook Folio G1 - 12.5" - Intel Core m7 - 6Y75 - 8 GB RAM - 240 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core m7 (6th Gen) - 6Y75 / 1.2 GHz, up to 3.1 GHz / 4 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 240 GB SSD | Display | 12.5" LED backlight touchscreen 3840 x 2160 / Ultra HD 4K | Graphics | Intel HD Graphics 515 | Input Device | ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Battery | 4-cell - up to 7 hours | Security | Trusted Platform Module (TPM 1.2) Security Chip | Dimensions (WxDxH) | 29.2 cm x 20.9 cm x 1.24 cm | Weight | 1.07 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 3 years , Limited warranty - battery - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core m7 (6th Gen) 6Y75 / 1.2 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 240 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 12.5" |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 3840 x 2160 (Ultra HD 4K) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Ultra Slim Design, Ultra HD 4K ultra wide-viewing angle (UWVA) |
Audio & Video | |
Graphics Processor | Intel HD Graphics 515 |
Camera | Yes - 720p |
Sound | Four speakers, two microphones |
Audio Features | Output: Bang & Olufsen Audio |
Input | |
Type | Keyboard, ClickPad |
Keyboard Layout | UK |
Features | Volume control, ClickPad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | PCI Express Mini Card (M.2) |
Compliant Standards | IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell lithium polymer |
Installed Qty | 1 |
Capacity | 38 Wh |
Run Time | Up to 7 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt |
Connections & Expansion | |
Interfaces Details | 2 x USB-C (supports Thunderbolt) , Headphone/microphone combo jack |
Software | |
Software Included | CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, HP Spare Key, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, Drive Encryption, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software, HP Image Assistant (free download) |
Miscellaneous | |
Features | HP 3D DriveGuard, HP DuraKeys, HP SpareKey, HP BIOS Protection, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, Pre-boot Authentication, HP Sure Start with Dynamic Protection |
Included Accessories | Power adapter |
Compliant Standards | MIL-STD 810G |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.07 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - battery - 3 years |
