The HP EliteBook 840 thin and light notebook allows users to be ultra-productive in and out of the office. Work with confidence thanks to proven technologies, security, performance, and management features that will meet all your enterprise needs.
Product Description | HP EliteBook 840 G2 Notebook - 14" - Intel Core i7 - 5600U - vPro - 8 GB RAM - 256 GB SSD - 4G LTE - UK | Product Type | Notebook | Operating System | Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English | Platform Technology | Intel vPro Platform | Processor | Intel Core i7 (5th Gen) - 5600U / 2.6 GHz, up to 3.2 GHz / 4 MB Cache | Memory | 8 GB DDR3L (1 x 8 GB) | Storage | 256 GB SSD - SED | Display | 14" LED backlight 1920 x 1080 / Full HD | Graphics | AMD Radeon R7 M260X / Intel HD Graphics 5500 | Video Memory | 1 GB GDDR5 SDRAM | Input Device | Pointing stick | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet | Wireless Broadband (WWAN) | 4G LTE | Service Provider | Service not included | Battery | 3-cell - up to 16 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 33.9 cm x 23.7 cm x 2.1 cm | Weight | 1.55 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English |
Processor / Chipset | |
CPU | Intel Core i7 (5th Gen) 5600U / 2.6 GHz |
Max Turbo Speed | 3.2 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 4 MB |
64-bit Computing | Yes |
Features | Enhanced SpeedStep technology, Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD SATA 6Gb/s - Self-Encrypting Drive |
Display | |
Type | 14" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Features | Multi-Stream transport (MST), Slim Design, Full HD ultra wide-viewing angle (UWVA) eDP anti-glare +PSR |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | AMD Radeon R7 M260X / Intel HD Graphics 5500 |
Video System Features | AMD PowerPlay Technology, AMD Dynamic Switchable Graphics |
Camera | Yes - 1280 x 720 |
Camera Features | 720p HD movie recording, low light enhancement |
Sound | Stereo speakers, two microphones |
Codec | Realtek ALC3228 |
Compliant Standards | High Definition Audio, DTS Studio Sound, DTS SOUND+ |
Input | |
Type | Keyboard, touchpad, pointing stick |
Keyboard Layout | UK |
Features | Volume control, spill-resistant |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2) |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I218-LM |
Features | Gobi Technology |
Compliant Standards | IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Wireless Broadband (WWAN) | |
Generation | 4G |
Technology | GSM, GPRS, EDGE, LTE, DC-HSPA+ |
Controller | HP lt4112 |
Max Transfer Rate | 100 Mbps |
Navigation | |
Receiver | GPS/GLONASS |
Battery | |
Technology | 3-cell lithium polymer |
Max Supported Qty | 2 |
Capacity | 50 Wh |
Run Time | Up to 16 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 18.5 V |
Connections & Expansion | |
Interfaces | DisplayPort , 4 x USB 3.0 , LAN , Dock , Battery , Headphone/microphone combo jack , VGA |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Software | |
Software Included | Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Systems Software Manager (free download), HP PageLift, HP Secure Erase, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Client Security Manager, LANDesk Management Suite (free download), HP Device Access Manager, HP CIK for Microsoft SCCM (free download) |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Dockable | Yes |
Features | Easy access door, HP 3D DriveGuard, Intel Active Management Technology (iAMT), HP DuraFinish, HP DuraKeys, HP SpareKey, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, UEFI BIOS, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, Intel My WiFi Technology, 1 USB 3.0 charging port |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC, CIT |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.55 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
