The HP EliteBook 840 thin and light notebook allows users to be ultra-productive in and out of the office. Work with confidence thanks to proven technologies, security, performance, and management features that will meet all your enterprise needs.
Product Description | HP EliteBook 840 G2 Notebook - 14" - Intel Core i5 - 5200U - 4 GB RAM - 1 TB HDD - UK | Product Type | Notebook | Operating System | Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English | Processor | Intel Core i5 (5th Gen) - 5200U / 2.2 GHz, up to 2.7 GHz / 3 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 1 TB HDD / 7200 rpm + 32 GB SSD cache (M.2) | Display | 14" LED backlight 1600 x 900 / HD+ | Graphics | Intel HD Graphics 5500 | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac, NFC, Gigabit Ethernet | Battery | 3-cell - up to 12.25 hours | Dockable | Yes | Security | Trusted Platform Module (TPM) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 33.9 cm x 23.7 cm x 2.1 cm | Weight | 1.55 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English |
Processor / Chipset | |
CPU | Intel Core i5 (5th Gen) 5200U / 2.2 GHz |
Max Turbo Speed | 2.7 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 1 TB HDD SATA 3Gb/s / 7200 rpm |
SSD Cache | 32 GB (M.2) |
Display | |
Type | 14" - TN |
LCD Backlight Technology | LED backlight |
Resolution | 1600 x 900 (HD+) |
Widescreen | Yes |
Features | HD+ standard-viewing angle (SVA) eDP anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 5500 |
Camera | Yes - 720p |
Camera Features | 720p HD movie recording |
Sound | Stereo speakers, two microphones |
Codec | Realtek ALC3228 |
Compliant Standards | High Definition Audio, DTS Studio Sound |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Volume control, spill-resistant, touchpad with gesture support |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac, NFC |
Bluetooth Class | Class 2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I218-LM |
Compliant Standards | IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 3-cell lithium polymer |
Installed Qty | 1 |
Max Supported Qty | 2 |
Capacity | 50 Wh |
Run Time | Up to 12.25 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Interfaces | DisplayPort , 4 x USB 3.0 , LAN , Dock , Battery , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Software | |
Software Included | Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP Recovery Manager, HP Support Assistant, HP Connection Manager, HP ePrint, HP Device Manager, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Client Security, HP PageLift, HP Secure Erase, Intel My WiFi, HP Client Security Manager, HP Roaming Alert |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Dockable | Yes |
Features | HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DuraCase, HP BIOS Protection, UEFI BIOS, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, 1 USB 3.0 charging port |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.55 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 200 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 0.75 g @ RMS (random) |
Vibration Tolerance (non-operating) | 1.5 g @ RMS (random) |
