Experience beauty and power that goes beyond expectations with the HP Elite x2 1012. It's 2 in 1 with precision-crafted keyboard, and a thin and light powerhouse designed to the exacting standards of the enterprise.
Mobility and style without compromise
Strikingly thin and elegant, the Elite x2 1012 is a 2 in 1 for the mobile workforce and executives who want no compromises when it comes to enterprise-class power, durability, optional LTE connectivity4 and productivity on the go, in a stylish design.
Designed for IT, loved by users
Stunning IT friendly design. Elite x2 1012 incorporates Elite global enterprise-class security and manageability features, enterprise-class durability, on-site serviceability, global sku availability and support across 180 countries.
Accessories built for how you work
At your desk or on the road, meet the specific needs of your work day with the included HP Active Pen with App Launch that uses Wacom technology. Accessorize to boost your efficiency. Add optional enterprise docking solutions3 and advanced keyboards.
Featuring
The tools you need to succeed
Start, work, and transition between modes easily with Window 10 Pro.1
A great mobile productivity keyboard
Superb typing experience, with high performance keyboards for productivity on the go with the HP Elite x2 1012 keyboard options3.
Capture spontaneous ideas
Create with the precision and accuracy of industry preferred Wacom technology in the HP Active Pen with App Launch.
Performance to get the job done
The quiet fanless design and 10 hours of battery life8 lets you work, surf, and connect with colleagues.
Speedy transfers
Charge devices, transfer data quickly, and connect to 4k devices with the USB-C™ port with Thunderbolt™ technology.
Connect and collaborate in style
Conduct virtual meetings with Audio by Bang & Olufsen, HP Noise Reduction Software and front/back camera.
Powerful defenses for data and devices
Help keep sensitive information safe with the latest with Windows 10 Pro1 and HP Client Security5 technology solutions.
Management made easy
Reduce management time thanks to the 2-in-1 design and HP Client Management Solutions9 and optional Intel® vPro.™
Valuable support at your service
Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that’s available 24x7, covering multiple brands, devices and operating systems.
Product Description | HP Elite x2 1012 G1 - 12" - Intel Core m5 - 6Y57 - vPro - 8 GB RAM - 256 GB SSD - UK | Product Type | Tablet - with detachable keyboard | Operating System | Win 10 Pro 64-bit - English | Platform Technology | Intel vPro Platform | Processor | Intel Core m5 (6th Gen) - 6Y57 / 1.1 GHz, up to 2.8 GHz / 4 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD | Display | 12" LED backlight touchscreen 1920 x 1280 / WUXGA+ | Graphics | Intel HD Graphics 515 | Input Device | Keyboard, digital pen, ClickPad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Battery | 4-cell - up to 10.25 hours | Features | Ambient light sensor, proximity sensor, hall sensor | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Dimensions (WxDxH) - tablet | 30 cm x 21.35 cm x 0.805 cm | Weight | 820 g | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core m5 (6th Gen) 6Y57 / 1.1 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 12" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 1920 x 1280 (WUXGA+) |
Widescreen | Yes |
Image Aspect Ratio | 3:2 |
Image Brightness | 340 cd/m² |
Features | Ultra Slim Design, Direct Bonding technology, Full HD ultra wide-viewing angle (UWVA) BrightView eDP, Corning Gorilla glass 4 |
Audio & Video | |
Graphics Processor | Intel HD Graphics 515 |
Camera | Yes - 1080p |
Resolution | 5 Megapixel (rear), 2 Megapixel (front) |
Camera Features | 1080p Full HD movie recording, low light enhancement, rear camera with flash |
Sound | Stereo speakers, two microphones |
Audio Features | Output: noise-cancellation technology, Bang & Olufsen Audio |
Input | |
Type | Keyboard, digital pen, ClickPad |
Keyboard Layout | UK |
Features | Volume control, touchpad with gesture support, gesture function |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Bluetooth Class | Class 2 |
Wireless Controller | PCI Express Mini Card (M.2) |
Features | Intel Wireless Display (WiDi) |
Compliant Standards | IEEE 802.11i, Wi-Fi CERTIFIED |
Battery | |
Technology | 4-cell lithium polymer |
Installed Qty | 1 |
Max Supported Qty | 1 |
Capacity | 40 Wh |
Run Time | Up to 10.25 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 5 / 12 / 15 V, 1.4 A |
Connections & Expansion | |
Interfaces Details | USB-C (supports Thunderbolt 3) , USB 3.0 , Headphone/microphone combo jack , Dock |
Memory Card Reader | Yes (microSD, microSDHC, microSDXC) |
Software | |
Software Included | Cyberlink PowerDVD, CyberLink Power2Go, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Foxit PhantomPDF Express, Intel Wireless Display, Windows Defender, HP Client Security, HP Mobile Connect, HP Systems Software Manager (free download), HP Security Manager, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Driver Packs, LANDesk Management Suite (free download), HP CIK for Microsoft SCCM (free download), HP Touchpoint Manager, Wacom Pen App, HP Noise Reduction Software |
Miscellaneous | |
Integrated Options | Ambient light sensor, proximity sensor, hall sensor |
Dockable | Yes |
Features | HP DuraKeys, HP SpareKey, Accelerometer, built-in adjustable tilt stand, HP BIOS Protection, magnetometer, gyroscope, microphone with echo and noise-cancellation, HP SureStart, HP Drive Encryption, HP Automatic Drive Lock, HP DriveLock, Master Record Security, Power On Authentication, Pre-Boot Security |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington nano security slot |
Included Accessories | Power adapter, keyboard, HP Active Pen, HP Elite x2 1012 G1 Travel Keyboard |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 820 g |
Dimensions (WxDxH) / Weight Details | 30 cm x 21.35 cm x 1.345 cm / 1.205 kg - tablet with keyboard , 30 cm x 21.93 cm x 0.61 cm / 385 g - keyboard dock |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance (operating) | 40 g @ 2 ms half-sine pulse |
Shock Tolerance (non-operating) | 240 g @ 2 ms half-sine pulse |
Vibration Tolerance (operating) | 1.043 g @ RMS (random) |
Vibration Tolerance (non-operating) | 3.5 g @ RMS (random) |
