ITEM | QTY | PRICE |
StarTech.com 8in LFH 59 Male to Femal...
4 | £43.76 |
Elevate your business with an ultrathin, professional laptop that empowers users to perform at their very best. Enterprise-class features, comprehensive security, and a refined collaboration experience handle even the most demanding tasks with streamlined efficiency.
Strong security, powerful manageability
Get powerful protection and simplified management from HP’s most secure and manageable PCs. HP Sure Start Gen3 protects against BIOS attacks and easily manage devices through Microsoft SCCM with HP Manageability Integration Kit.
High performance, high portability
Speed up demanding business applications and data. Combine high-performance and long battery life with 7th Gen Intel® Core™ processors, and PCIe Gen3 solid state drives. Amplify performance with up to 32 GB of DDR4 memory.
Thin design, no adapters needed
Give portability a whole new meaning with an ultrathin design that doesn’t cut corners. Starting at an incredible 18.9mm, the HP EliteBook 820 includes several ports like full-size VGA, DisplayPort™, RJ-45, and enterprise docking.
See and hear them clearly
Give your online collaboration the sharpness and clarity of a face-to-face meeting with HP Audio Boost, HP Noise Cancellation software, Audio by Bang & Olufsen, and an optional 720p webcam.
Product Description | HP EliteBook 820 G4 Notebook - 12.5" - Intel Core i5 - 7200U - 4 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit - English | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 4 GB DDR4 (1 x 4 GB) | Storage | 256 GB SSD - HP Turbo Drive | Display | 12.5" LED backlight 1366 x 768 / HD - 125 ppi | Graphics | Intel HD Graphics 620 | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 3-cell - up to 14.75 hours | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Dimensions (WxDxH) | 31 cm x 21.89 cm x 1.89 cm | Weight | 1.26 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | Limited warranty - 3 years , Limited warranty - battery - 3 years |
General | |
Operating System | Windows 10 Pro 64-bit Edition - English |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz / PC4-17000 |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD PCIe - HP Turbo Drive |
Display | |
Type | 12.5" - TN |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Pixel Density (ppi) | 125 |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Slim Design, HD standard-viewing angle (SVA) eDP anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - 720p |
Sound | Stereo speakers, two microphones |
Audio Features | Output: noise-cancellation technology, Bang & Olufsen Audio, HP Audio Boost |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Touchpad with gesture support |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-V |
Remote Management Protocol | SNMP 2 |
Features | Wake-on-LAN (WOL) |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, IEEE 802.3ae, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery | |
Technology | 3-cell lithium polymer |
Capacity | 49 Wh |
Run Time | Up to 14.75 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19.5 V |
Connections & Expansion | |
Slots | 1 x SIM card (1 free) |
Interfaces Details | USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , USB-C , DisplayPort , VGA , LAN , Dock , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Software | |
Software Included | Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Client Security, HP Systems Software Manager (free download), HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Mobile Connect Pro, HP JumpStart, HP JetAdvantage Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP MAC Address Manager, HP MIK for Microsoft SCCM (free download) |
Miscellaneous | |
Case Material | Aluminum, magnesium alloy |
Dockable | Yes |
Features | HP 3D DriveGuard, HP DuraKeys, HP DriveLock, Master Record Security, Power On Authentication, Pre-boot Authentication, HP Sure Start Gen 3 |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI, RoHS, WEEE, Common Criteria EAL4+ |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.26 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - battery - 3 years |
