Essential Mobility. Optimized for Windows 8 Pro, this value-priced notebook offers Intel technology, wireless capabilities and essential multimedia tools. The durable casing in a matte charcoal color protects the laptop's good looks.
Product Description | HP 650 - 15.6" - Intel Celeron 1000M - 4 GB RAM - 500 GB HDD | Product Type | Notebook | Operating System | Win 8 64-bit | Processor | Intel Celeron 1000M / 1.8 GHz / 2 MB Cache | Memory | 4 GB DDR3 | Storage | 500 GB HDD / 5400 rpm | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight HD anti-glare 1366 x 768 / HD | Graphics | Intel HD Graphics | Integrated Webcam | Yes | Networking | 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet | Battery | 6-cell - up to 6 hours | Colour | Charcoal | Dimensions (WxDxH) | 37.6 cm x 24.7 cm x 3.58 cm | Weight | 2.45 kg | Microsoft Office Preloaded | Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC. | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified EPEAT Silver | Manufacturer Warranty | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
General | |
Recommended Use | Small business, corporate business |
Operating System | Windows 8 64-bit Edition |
Processor / Chipset | |
CPU | Intel Celeron 1000M / 1.8 GHz |
Number of Cores | Dual-Core |
Cache | 2 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel HM75 Express |
Memory | |
RAM | 4 GB |
Max RAM Supported | 8 GB |
Technology | DDR3 SDRAM |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Storage | |
Main Storage | 500 GB HDD SATA 3Gb/s / 5400 rpm |
Optical Drive | DVD±RW (±R DL) / DVD-RAM fixed - tray |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | HD anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics |
Camera | Yes |
Sound | Stereo speakers, microphone |
Compliant Standards | High Definition Audio |
Audio Features | Output: Altec Lansing speakers |
Input | |
Type | Keyboard, touchpad |
Features | Multi-touch touchpad |
Communications | |
Wireless | 802.11b/g/n, Bluetooth 4.0 |
Network Interface | Gigabit Ethernet |
Remote Management Protocol | SNMP |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, Wi-Fi CERTIFIED |
Battery | |
Technology | 6-cell Lithium Ion |
Capacity | 47 Wh |
Run Time | Up to 6 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 18.5 V |
Connections & Expansion | |
Interfaces | VGA , HDMI , Headphone output , Microphone input , LAN , 3 x USB 2.0 |
Memory Card Reader | Yes (SD Card, MultiMediaCard) |
Software | |
Software Included | Norton Internet Security 2012 (60 days trial), HP Wireless Hotspot (free download) |
Miscellaneous | |
Colour | Charcoal |
Features | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.45 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance | 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating) |
Vibration Tolerance | 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating) |
