Your Business Partner. Optimized for Windows 8 Pro, these notebooks are ideal for SMBs. They offer multimedia tools, easy-to-use security, aluminum casing for added protection and 39,6 cm (15.6") diagonal HD display. Gain discrete graphics and battery-saving mode.
Product Description | HP ProBook 4540s - 15.6" - Intel Core i3 3110M - 4 GB RAM - 320 GB HDD | Product Type | Notebook | Operating System | Win 8 Pro 64-bit | Processor | Intel Core i3 (3rd Gen) 3110M / 2.4 GHz / 3 MB Cache | Memory | 4 GB DDR3 | Storage | 320 GB HDD / 7200 rpm | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight HD anti-glare 1366 x 768 / HD | Graphics | Intel HD Graphics 4000 | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet | Battery | 6-cell - up to 7 hours | Colour | Brushed aluminum | Dimensions (WxDxH) | 37.5 cm x 25.6 cm x 2.8 cm | Weight | 2.47 kg | Microsoft Office Preloaded | Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC. | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified EPEAT Gold | Manufacturer Warranty | Limited warranty - 1 year , Limited warranty - battery - 1 year |
General | |
Recommended Use | Small business, corporate business |
Operating System | Windows 8 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i3 (3rd Gen) 3110M / 2.4 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel HM76 Express |
Memory | |
RAM | 4 GB |
Max RAM Supported | 8 GB |
Technology | DDR3 SDRAM |
Speed | 1333 MHz / PC3-10600 |
Rated Speed | 1333 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Storage | |
Main Storage | 320 GB HDD SATA 3Gb/s / 7200 rpm |
Optical Drive | DVD±RW (±R DL) / DVD-RAM fixed - tray |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | HD anti-glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 4000 |
Camera | Yes |
Resolution | 0.92 Megapixel |
Video Resolutions | 1280 x 720 |
Sound | Stereo speakers, stereo microphone |
Codec | IDT 92HD87 |
Compliant Standards | High Definition Audio |
Audio Features | Output: SRS Premium Sound |
Input | |
Type | Keyboard, touchpad |
Features | Spill-resistant |
Communications | |
Wireless | 802.11b/g/n, Bluetooth 4.0 |
Bluetooth Class | Class 2 |
Network Interface | Gigabit Ethernet |
Remote Management Protocol | SNMP |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.3az |
Battery | |
Technology | 6-cell Lithium Ion |
Capacity | 47 Wh |
Run Time | Up to 7 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 18.5 V |
Connections & Expansion | |
Interfaces | 2 x USB 2.0 , 2 x USB 3.0 , Microphone input , Headphone output , HDMI , LAN , VGA |
Memory Card Reader | Yes (SD Card, Memory Stick, MultiMediaCard, MMCplus, SDHC Card, SDXC Card) |
Software | |
Software Included | WinZip, HP ProtectTools Security Manager, HP Wireless Assistant, HP Recovery Manager, HP Support Assistant, HP Power Assistant, HP Connection Manager, HP Face Recognition, Microsoft Office 2010 Starter, ArcSoft TotalMedia Suite, HP Hotkey Support, Credential Manager for HP ProtectTools, Drive Encryption for HP ProtectTools, HP Spare Key |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, Enhanced Pre-Boot Security, HP SpareKey, HP File Sanitizer |
Included Accessories | Power adapter |
Compliant Standards | ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, A-Tick, ICES, KC |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 2.47 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Limited warranty - battery - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Shock Tolerance | 40 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating) |
Vibration Tolerance | 0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating) |
