ITEM | QTY | PRICE |
Microsoft Xbox Series X - Grade A
4 | £1,516.00 |
Everything you need every day, ready with one simple connection. The HP 3005pr USB 3.0 Port Replicator is our ultimate platform-independent hot desking solution. Get online, make up to six of your everyday USB devices immediately available, and expand your productivity with connection to two external displays-all through one USB 3.0 cable.
Product Description | HP 3005pr USB 3.0 Port Replicator - docking station - USB - 1GbE | Product Type | Docking station | Docking Interface | USB | Dimensions (WxDxH) | 21.95 cm x 7.02 cm x 2.52 cm | Weight | 235 g | Localisation | English / United Kingdom | Networking | Gigabit Ethernet | Power | Power adapter - external AC 120/230 V (50/60 Hz) | Manufacturer Warranty | 1-year warranty |
General | |
Width | 21.95 cm |
Depth | 7.02 cm |
Height | 2.52 cm |
Weight | 235 g |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | IEEE 802.3 |
Expansion / Connectivity | |
Interfaces | 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 4 x USB 2.0 - 4 pin USB Type A , 1 x microphone - input - mini-phone 3.5 mm , 1 x headphones - output - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x audio / video - DisplayPort - 20 pin DisplayPort |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | UL, C-Tick, BSMI, VCCI Class B ITE, cUL, SABS, CB, FCC, ICES, GOST-R, UkrSEPRO |
Power | |
Power Device | Power adapter - external |
Voltage Required | AC 120/230 V (50/60 Hz) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - 1 year |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
