Boost the capabilities of your HP Business Desktop PC and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements.
HP-tested
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that’s been tested for seamless system-level integration with HP PCs.
Supported by HP
Protect your investment with the same world-class HP limited warranty you get for your PC.
Product Description | HP - DDR4 - module - 16 GB - SO-DIMM 260-pin - 2133 MHz / PC4-17000 - unbuffered | Product Type | Memory module | Capacity | 16 GB | Memory Type | DDR4 SDRAM - SO-DIMM 260-pin | Upgrade Type | System specific | Data Integrity Check | Non-ECC | Speed | 2133 MHz (PC4-17000) | Latency Timings | CL15 | Features | Unbuffered | Voltage | 1.2 V | Manufacturer Warranty | 1-year warranty | Designed For | HP 260 G2; Elite Slice, Slice for Meeting Rooms; EliteDesk 705 G3 (mini desktop), 800 G2 (mini desktop); EliteOne 800 G2; ProDesk 400 G2 (mini desktop), 600 G2 (mini desktop); ProOne 400 G2, 600 G2; Retail System MP9 G2; RP9 G1 Retail System 9015, 9018, 9118 |
General | |
Capacity | 16 GB |
Memory | |
Type | DRAM memory module |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Module Height (inch) | 1.18 |
Voltage | 1.2 V |
Manufacturer Warranty | |
Service & Support | 1-year warranty |
Compatibility Information | |
Designed For | HP 260 G2 , HP Elite Slice, Slice for Meeting Rooms , HP EliteDesk 705 G3 (mini desktop), 800 G2 (mini desktop) , HP EliteOne 800 G2 , HP ProDesk 400 G2 (mini desktop), 600 G2 (mini desktop) , HP ProOne 400 G2, 600 G2 , HP Retail System MP9 G2 , HP RP9 G1 Retail System 9015, 9018, 9118 |
