Samsung TV Promotion: Save up to £400 across the range.
HP 125 Wired Keyboard USB
free standard delivery
£15.75
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • The three zone, full size HP 125 Wired Keyboard includes 0-6 degree adjustable feet so you'll be able to type comfortably. Plus, an LED indicator for the Caps, Number and Function lock easily reminds you when these features are active.
  • Connecting some peripheral devices can be a complex and time consuming task. Who needs that? With easy plug and play USB connectivity, you can get your keyboard connected quickly so you can get on with your work day.
  • You should feel good about the products you buy and use. Rest assured, this keyboard is responsibly made with over 50% of the plastics comprised of recycled materials.
  • Use your keyboard every day and it will accumulate dirt and grime. Over time, this can affect how it performs. Because it was specifically designed to withstand every day cleaning with disinfecting wipes, this is one keyboard that's a snap to keep clean.
  • Recommended Use: Office
  • Type: Keyboard, Keypad, Keyboard
  • Wired / Wireless: Wired
  • Colour: Black, Dark
  • Compatibility: PC
Product codes
chevron icon
chevron icon
Think how much you use your keyboard. That's why we've taken the time to design a keyboard that is comfortable to use so you can work productively every day - and all day if necessary.
chevron icon
Product Description HP 125 - keyboard - UK
Device Type Keyboard
Interface USB
Connectivity Technology Wired
Localization and Layout UK
Dimensions (WxDxH) 43.6 cm x 13.8 cm x 2.03 cm
Manufacturer Warranty 1-year warranty
Designed For HP 34; Elite Mobile Thin Client mt645 G7; Laptop 15; Presence Small Space Solution Plus AI Camera with Zoom Rooms, Small Space Solution with Microsoft Teams Rooms, Small Space Solution with Zoom Rooms; Pro 290 G9; Pro Mobile Thin Client mt440 G3
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£15.75
