Samsung TV Promotion: Save up to £250 across the range.
HP 125 Mouse Wired USB Black for ProBook 45X G9, 635 640 G8, ZB
free standard delivery
£9.87
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • The HP 125 Wired Mouse includes perfectly positioned left and right buttons and a scroll wheel so you can work in comfort all day.
  • Connecting some peripheral devices can be a complex and time consuming task. Who needs that? With easy plug and play USB connectivity, you can get your mouse connected quickly so you can get on with your work day.
  • You should feel good about the products you buy and use. Rest assured, this wired mouse is responsibly made with printed circuit boards that is low halogen.
  • Use your mouse every day and it will accumulate dirt and grime. Over time, this can affect how it performs. Because it was specifically designed to withstand everyday cleaning with disinfecting wipes, this is one mouse that's a snap to keep clean.
  • Recommended Use: Office
  • Type: Mouse
  • Wired / Wireless: Wired
  • Colour: Black, Dark
  • Compatibility: PC
Product codes
chevron icon
chevron icon
Think how much you use your mouse. That's why we've taken the time to design a wired mouse that is comfortable to use so you can work productively every day - and all day if necessary.
chevron icon
Product Description HP 125 - mouse - USB - black
Device Type Mouse
Connectivity Technology Wired - USB
Colour Black
Dimensions (WxDxH) 6.3 cm x 11.2 cm x 3.6 cm
Weight 80.5 g
Features Scrolling wheel
Cable Length 180 cm
Manufacturer Warranty 1-year warranty
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£9.87
