Simply solid colossal storage. Touro Desk external drive provides solid add-on storage for all your photos, movies, music and documents. Stackable, with plug and play simplicity, Touro Desk comes with all the quality and reliability you expect from Hitachi. Hitachi Global Storage Technologies (Hitachi GST) develops advanced hard disk drives, enterprise-class solid state drives, and innovative external storage solutions and services to store, preserve and manage the world's most valued data.
Includes
Product Description | WD Touro Desk DX3 HTOLDX3EB40001ABB - hard drive - 4 TB - USB 3.0 | Type | Hard drive - external (desktop) | Capacity | 4 TB | Form Factor | 3.5" | Interface | USB 3.0 | Spindle Speed | 5400 rpm | Enclosure Colour | Black | Dimensions (WxDxH) | 12.9 cm x 6 cm x 18.3 cm | Weight | 0.97 kg | Localisation | EMEA | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - external (desktop) |
Capacity | 4 TB |
Width | 12.9 cm |
Depth | 6 cm |
Height | 18.3 cm |
Weight | 0.97 kg |
Performance | |
Expansion & Connectivity | |
Compatible Bay | 3.5" |
Power | |
Power Device | Power adapter |
Software & System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later |
Miscellaneous | |
Cables Included | 1 x USB cable |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
The following resources are available for the HGST 4TB Touro Desk USB 3.0 5400RPM 3.5" Desktop Hard Drive
