Chromecast Audio
Stream your favourite tunes from your phone to speakers in the home.
What is Chromecast Audio?
Chromecast Audio is a small device that plugs into your speaker for streaming music through Wi-Fi.
Once set up, simply use your iPhone®, iPad®, Android phone and tablet, Mac® and Windows® laptop, or Chromebook to stream your favourite tunes to the best speakers in the house.
Speaker inputs supported:
RCA
3.5 mm (3.5 mm cable included)
Optical
Easily stream music, without the hassle of pairing
Tap the Cast button from music apps to hear the music instantly on your speakers. Search, play, pause, queue songs and turn up the volume right from your phone – anywhere in the house.
Listen to your favourites, any time
Enjoy over 30 million songs from music services like Google Play Music, Deezer & Spotify. We're constantly adding new apps, so there's no end to the music, radio stations and podcasts that you can enjoy.
Plus, stream any audio from your Android phone or your laptop
For apps that are not yet cast-enabled or music stored on your device, you can stream audio from your Android phone or tablet to the speaker. Or, use your laptop to stream music and audio streaming websites from the Chrome browser.
Make your speaker smart(er) for less
Chromecast Audio is an affordable way to enjoy the music you love on your existing speakers.
Tap to party
Your friends and family can join in the fun, too. Anyone in the home can cast music to your speakers using their own phones – no additional setup or pairing required.
Enjoy higher quality sound
Listen to your favourite artists the way they were meant to be heard. Chromecast Audio supports lossless high-resolution audio, which is even better than CD quality sound. And your music streams from the cloud so you get continuous high-quality sound – even when you leave the room.
Play music everywhere with Multi-room
Multi-room lets you group Chromecast Audio devices together so that you can listen to the same song on multiple speakers.
Jam out to your music without interruption
Casting won’t drain your battery or get in the way of other activities. Answer a call, surf the web, even leave the room – all without interrupting the tunes.
Product Description | Google Chromecast Audio - network audio player | Product Type | Network audio player | Audio Channels | Stereo | Source | Network | Streaming Services | Pandora, Rhapsody, Spotify, TuneIn, Google Play Music, iHeartRadio | Interfaces | Wi-Fi | Dimensions (WxDxH) | 5.19 cm x 5.19 cm x 1.349 cm | Weight | 30.7 g |
General | |
Audio System | |
Functions | Network audio player, internet radio |
Source | Network |
Audio D/A Converter | 16bit / 96kHz |
Features | Upgradeable firmware, USB bus-powered, smartphone remote controlled |
Network & Internet Multimedia | |
Connections | |
Connectors | Audio line-out (mini-phone stereo 3.5 mm / optical) , USB (5 pin Micro-USB Type B (power only)) |
Miscellaneous | |
Included Accessories | Audio cable, power adapter, power cable |
Dimensions & Weight | |
Width | 5.19 cm |
Depth | 5.19 cm |
Height | 1.349 cm |
Weight | 30.7 g |
