OC GURU ll
Brand-new instinctive user interface, easier to monitoring and adjusting all important settings. Users can set up MONITORING, GPU CLOCK, MEMORY CLOCK, FAN, GPU VOLTAGE, Memory VOLTAGE, OSD, ONLINE SUPPORT and update driver, BIOS directly.
NEW WINDFORCE 3X 2 SLOT 450W cooling system
Keeping the same 450W Cooling capacity using only 2 slots, the New WINDFORCE 3X 450W cooling system is equipped with two 8mm and four 6mm cooper heat-pipes , inclined fans, and GIGABYTE "Triangle Cool" technology. This not only provides an effective heat dissipation capacity but GPU Boost 2.0 technology also enables higher performance due to a lower temperature.
Up to 4 displays on a Single Card
In the Kepler architecture, support up to four displays on a single card. Satisfy your mulit-screen steup, high definition and extreme gaming experience.
Product Description | Gigabyte GV-N780OC-3GD - graphics card - GF GTX 780 - 3 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | NVIDIA GeForce GTX 780 | Memory | 3 GB GDDR5 | Core Clock | 954 MHz | Boost Clock | 1006 MHz | Effective Memory Clock | 6.008 GHz | Memory Interface | 384-bit | Max Resolution | 2560 x 1600 | Max Resolution Details | DVI: 2560 x 1600 / VGA: 2048 x 1536 | Max Monitors Supported | 4 | Interfaces | DVI-I (dual link) , DVI-D , HDMI , DisplayPort | API Supported | OpenGL 4.3 | Dimensions (WxDxH) | 4.3 cm x 29.2 cm x 12.9 cm |
General | |
Process Technology | 28 nm |
Features | Dual Slot Fan Cooler, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 3x, Nvidia SLI ready, Triangle Cool Technology, NVIDIA Adaptive Vertical Sync, Kepler GPU Architecture, OC Guru II, NVIDIA GPU Boost 2.0 |
Memory | |
Size | 3 GB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 6.008 GHz |
Bus Width | 384-bit |
System Requirements | |
Required Power Supply | 600 W |
Miscellaneous | |
Width | 4.3 cm |
Depth | 29.2 cm |
Height | 12.9 cm |
