Key Features
Product Description | Gigabyte GV-N760OC-2GD - graphics card - GF GTX 760 - 2 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | NVIDIA GeForce GTX 760 | Memory | 2 GB GDDR5 | Core Clock | 1085 MHz | Boost Clock | 1150 MHz | Effective Memory Clock | 6.008 GHz | Memory Interface | 256-bit | Max Resolution | 4096 x 2160 | Max Monitors Supported | 4 | Interfaces | DisplayPort , HDMI , DVI-I (dual link) , DVI-D | API Supported | DirectX 11.1, OpenGL 4.3 | Dimensions (WxDxH) | 4.3 cm x 27.5 cm x 13.66 cm |
General | |
Process Technology | 28 nm |
Features | Ultra Durable VGA, Nvidia PhysX-Ready, Nvidia 3D Vision technology, GIGABYTE WindForce 3x, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, OC Guru II |
Memory | |
Size | 2 GB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 6.008 GHz |
Bus Width | 256-bit |
System Requirements | |
Required Power Supply | 500 W |
Miscellaneous | |
Software Included | OC Guru ll |
Width | 4.3 cm |
Depth | 27.5 cm |
Height | 13.66 cm |
