GIGABYTE engineers have developed an ultra compact PC with a stylish design based around an anthracite aluminum frame and glass surface chassis. Ideal for a broad range of computing applications at home or in the office, the BRIX expounds sheer simplicity and convenience, sets a new standard for desktop miniaturization that makes it perfect as a discreet HTPC / multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit. The BRIX is an ultra compact, versatile DIY PC kit that redefines the desktop PC in terms of miniaturization with a form factor that is small enough (56mm x 107mm x 114mm) to sit in the palm of your hand.
Product Description | Gigabyte BRIX GB-BXBT-2807 (rev. 1.0) - Ultra Compact PC Kit - Celeron N2807 1.58 GHz - 0 GB - no HDD | Type | PC barebone - Ultra Compact PC Kit - UEFI BIOS | Processor | 1 x Intel Celeron N2807 / 1.58 GHz (, up to 2.16 GHz, (Dual-Core) | Processor Main Features | Intel Burst Technology | Cache Memory | 1 MB | Cache Per Processor | 1 MB | RAM | 0 GB (installed) / 8 GB (max) - DDR3L SDRAM | Storage Controller | SATA (SATA 3Gb/s) | Hard Drive | No HDD | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics | Audio Output | Integrated | Networking | 1GbE, 802.11b/g/n, Bluetooth 4.0 | Power | AC 120/230 V | OS Provided | No operating system | Dimensions (WxDxH) | 10.76 cm x 11.44 cm x 5.61 cm |
General | |
Type | PC barebone |
Product Form Factor | Ultra Compact PC Kit |
Processor / Chipset | |
CPU | Intel Celeron N2807 |
Clock Speed | 1.58 GHz |
Max Turbo Speed | 2.16 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | 1 MB |
RAM | |
Installed Size | 0 GB / 8 GB (max) |
Technology | DDR3L SDRAM |
Form Factor | SO-DIMM 204-pin |
Slots | 1 (Total) / 1 (empty) |
Hard Drive | |
Type | No HDD |
Storage Controller | |
Type | 1 x SATA - integrated |
Controller Interface Type | SATA 3Gb/s |
Channel Qty | 1 |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Type | Integrated |
Graphics Processor | Intel HD Graphics |
Video Interfaces | VGA, HDMI |
Max Monitors Supported | 2 |
Audio Output | |
Type | Integrated |
Networking | |
Ethernet Controller | Realtek RTL8111G |
Wireless LAN Supported | Yes |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0 |
Compliant Standards | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0 |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" |
Slots | 1 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCIe Half Mini Card |
Interfaces | 1 x USB 3.0 (1 in front) , 1 x HDMI , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x audio line-out/microphone - mini-jack |
Miscellaneous | |
Included Accessories | VESA wallmount adapter |
Features | UEFI BIOS |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V |
Operating System / Software | |
Dimensions & Weight | |
Width | 10.76 cm |
Depth | 11.44 cm |
Height | 5.61 cm |
