Reversible dual USB Type-C with USB 3.1
The USB Type-C is a reversible connector that is loaded with useful features such as USB 3.1 support for 10 Gb/s transfer speed.
USB 3.0 and network connectivity
GIGABYTE BRIX also includes a M.2 module offering IEEE 802.11ac Wi-Fi and the latest Bluetooth 4.2, providing connectivity for low power Bluetooth devices and peripherals, as well as allowing users to easily connect mobile devices.
Native 4K HD decode support
The GIGABYTE BRIX now support a native resolution of 4K, bringing unrivaled visual clarity and stunning realism to owners of 4K HDTV or PC monitors. This also opens up possibilities for those in the digital signage interested in the small footprint of the GIGABYTE BRIX, and those in need of a 4K display solution capable of delivering an ultra-realistic, high definition visual experience.
Multi-display productivity with HDMI & DisplayPort++
BRIX supports up to three independent displays through HDMI and a DisplayPort ++ without the need for an additional graphics card. Support for three display is only possible with daisy-chain connections through Display Port++.
Product Description | Gigabyte BRIX GB-BSi7A-6500 (rev. 1.0) - Ultra Compact PC Kit - Core i7 6500U 2.5 GHz - 0 GB - no HDD | Type | PC barebone - Ultra Compact PC Kit | Processor | 1 x Intel Core i7 (6th Gen) 6500U / 2.5 GHz (, up to 3.1 GHz, (Dual-Core) | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 4 MB | Cache Per Processor | 4 MB | RAM | 0 GB (installed) / 32 GB (max) - DDR4 SDRAM | Hard Drive | No HDD | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics 520 | Audio Output | Stereo | Networking | GigE | Power | AC 120/230 V | OS Provided | No operating system | Dimensions (WxDxH) | 11.26 cm x 11.94 cm x 3.44 cm |
General | |
Type | PC barebone |
Product Form Factor | Ultra Compact PC Kit |
Processor / Chipset | |
CPU | Intel Core i7 (6th Gen) 6500U |
Clock Speed | 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | 4 MB |
RAM | |
Installed Size | 0 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 2 (empty) |
Hard Drive | |
Type | No HDD |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 520 |
Video Interfaces | HDMI, DisplayPort |
Audio Output | |
Sound Output Mode | Stereo |
Networking | |
Ethernet Controller | Intel I219-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Slots | 1 M.2 Card , 2 (total) / 2 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2280 |
Interfaces | 2 x USB 3.0 , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone - mini-jack (1 in front) , 1 x USB 3.1 (1 in front) , 1 x USB-C 3.1 (1 in front) |
Miscellaneous | |
Included Accessories | VESA wallmount adapter |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V |
Operating System / Software | |
Dimensions & Weight | |
Width | 11.26 cm |
Depth | 11.94 cm |
Height | 3.44 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
