This is a compact PC with a brushed aluminum surface chassis design. Ideal for a broad range of computing applications at home or in the office, it expounds sheer simplicity and convenience. It is perfect as a discreet HTPC/multimedia hub, an ultra-low power PC for the family, an office PC or as a digital signage unit.
Product Description | Gigabyte BRIX s GB-BKi3HA-7100 (rev. 1.0) - Ultra Compact PC Kit - Core i3 7100U 2.4 GHz - 0 GB - no HDD | Type | PC barebone - Ultra Compact PC Kit | Processor | 1 x Intel Core i3 (7th Gen) 7100U / 2.4 GHz (Dual-Core) | RAM | 0 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | No HDD | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics 620 | Audio Output | Stereo | Networking | 1GbE | Power | AC 120/230 V | OS Provided | No operating system | Dimensions (WxDxH) | 11.26 cm x 11.94 cm x 4.68 cm |
General | |
Type | PC barebone |
Product Form Factor | Ultra Compact PC Kit |
Processor / Chipset | |
CPU | Intel Core i3 (7th Gen) 7100U |
Clock Speed | 2.4 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
RAM | |
Installed Size | 0 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 2 (empty) |
Hard Drive | |
Type | No HDD |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Channel Qty | 1 |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 620 |
Video Interfaces | HDMI, DisplayPort |
Max Monitors Supported | 2 |
Audio Output | |
Sound Output Mode | Stereo |
Networking | |
Ethernet Controller | Intel I219-LM |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Bays | 1 (total) / 1 (free) x internal 2.5" |
Slots | 1 M.2 Card - 2230 , 2 (total) / 2 (free) x SO-DIMM 260-pin , 1 (total) / 1 (free) x M.2 Card - 2280 |
Interfaces | 2 x USB 3.0 , 1 x HDMI , 1 x Mini DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone - mini-jack (1 in front) , 1 x USB 3.1 (1 in front) , 1 x USB-C 3.1 (1 in front) |
Miscellaneous | |
Included Accessories | VESA wallmount adapter |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V |
Operating System / Software | |
Dimensions & Weight | |
Width | 11.26 cm |
Depth | 11.94 cm |
Height | 4.68 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
