Get to the next level with the EVGA GeForce GTX 680. This card delivers truly game-changing performance that taps into the powerful GeForce architecture to redefine smooth, seamless, lifelike gaming. It offers never before seen features that will redefine the way you think about performance graphics cards. Expect more from your graphics card that just state-of-the-art features and technology; get faster, smoother and a richer gaming experience with the EVGA GeForce GTX 680.
Performance
Resolution & Refresh
Key Features
Product Warranty
Operating System Support
Requirements
Product Description | EVGA GeForce GTX 680 FTW - graphics card - GF GTX 680 - 4 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | NVIDIA GeForce GTX 680 | Memory | 4 GB GDDR5 | Core Clock | 1084 MHz | Boost Clock | 1150 MHz | CUDA Cores | 1536 | Effective Memory Clock | 6.008 GHz | Memory Interface | 256-bit | Max Resolution | 2560 x 1600 | Max Resolution Details | DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536 | Max Monitors Supported | 4 | Interfaces | DVI-I (dual link) , DisplayPort , HDMI , VGA - with adapter , DVI-D (dual link) | API Supported | DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2 | Dimensions (WxDxH) | 26.67 cm x 11.115 cm | Manufacturer Warranty | 3-year warranty | Bundled with | EVGA Backplate |
General | |
CUDA Cores | 1536 |
Features | Integrated 7.1 channel HD Audio controller, Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Nvidia SLI ready, Deep Color technology, TXAA, SMX technology, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost, Nvidia Fast Approximate Antialiasing Technology (FXAA) |
Memory | |
Size | 4 GB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 6.008 GHz |
Bus Width | 256-bit |
Bandwidth | 192.25 GBps |
System Requirements | |
OS Required | Microsoft Windows Vista / XP / 7, Microsoft Windows Vista / XP / 7 (64-bit versions) |
Required Power Supply | 550 W |
Additional Requirements | Adjacent PCI slot, 6-pin + 8-pin power connectors |
Miscellaneous | |
Included Accessories | 2 x 6 pin to 8 pin power cables, 2 x 4 pin to 6 pin power cables |
Cables Included | 1 x DVI-VGA adapter |
Software Included | Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X |
Depth | 26.67 cm |
Height | 11.115 cm |
Weight | 1.36 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 3 years |
The following resources are available for the EVGA GeForce GTX 680 1110MHz 4GB PCI-Express 3.0 HDMI FTW
