Get to the next level with the EVGA GeForce GTX 680. This card delivers truly game-changing performance that taps into the powerful new GeForce architecture to redefine smooth, seamless, lifelike gaming. It offers brand new, never before seen features that will redefine the way you think about performance graphics cards. Expect more from your graphics card than just state-of-the-art features and technology; get a faster, smoother and richer gaming experience with the EVGA GeForce GTX 680.
No 1 American Nvidia Brand, EVGA warranty allows for overclocking, the consumer can replace the reference cooler for better overclocking and as long as they return the original cooler with the card then it will be covered by the EVGA warranty. There is Direct RMA with a 7 working day turn around, Step-up programme enables consumers to upgrade their graphics card within 3 months of purchase and only pay the difference for the more expensive card. EVGA forum offers advice, driver updates and special offers and the EVGA GPU purchase gives enthusiasts free online gaming with EVGA gaming servers.
Spec
Product Description | EVGA GeForce GTX 680 Superclocked - graphics card - GF GTX 680 - 2048 MB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | NVIDIA GeForce GTX 680 | Memory | 2048 MB GDDR5 | Core Clock | 1058 MHz | CUDA Cores | 1536 | Effective Memory Clock | 6.208 GHz | Memory Interface | 256-bit | Max Resolution | 2560 x 1600 | Max Resolution Details | DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / HDMI: 2560 x 1600 / VGA: 2048 x 1536 | Max Monitors Supported | 4 | Interfaces | DVI-I , DVI-D , HDMI , DisplayPort , VGA - with adapter | API Supported | DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2 | Dimensions (WxDxH) | 25.4 cm x 12.1 cm | Manufacturer Warranty | 3-year warranty | Bundled with | EVGA Backplate |
General | |
CUDA Cores | 1536 |
Max Resolution | 2560 x 1600 at 240 MHz |
Features | Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Nvidia SLI ready, TXAA, GPU Boost technology, Adaptive V-Sync, FXAA, SMX technology, HDCP |
Memory | |
Size | 2048 MB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 6.208 GHz |
Bus Width | 256-bit |
Bandwidth | 198.66 GBps |
System Requirements | |
OS Required | Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) |
Required Power Supply | 550 W |
Additional Requirements | CD-ROM, adjacent PCI slot, PCIe slot, two 6-pin power connectors |
Miscellaneous | |
Included Accessories | 2 x dual 4 pin to 6 pin power cables |
Software Included | Drivers & Utilities |
Depth | 25.4 cm |
Height | 12.1 cm |
Weight | 1.36 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
