Get to the next level with the EVGA GeForce GTX 670. This card delivers truly game-changing performance that taps into the powerful new GeForce architecture to redefine smooth, seamless, lifelike gaming. It offers brand new, never before seen features that will redefine the way you think about performance graphics cards. Expect more from your graphics card than just state-of-the-art features and technology; get a faster, smoother and richer gaming experience with the EVGA GeForce GTX 670.
Performance
Resolution & Refresh
Product Warranty
Operating System Support
Requirements
Product Description | EVGA GeForce GTX 670 Superclocked+ - graphics card - GF GTX 670 - 4 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | NVIDIA GeForce GTX 670 | Memory | 4 GB GDDR5 | Core Clock | 967 MHz | CUDA Cores | 1344 | Effective Memory Clock | 6.008 GHz | Memory Interface | 256-bit | Max Resolution | 2560 x 1600 | Interfaces | DVI-I , DVI-D , HDMI , DisplayPort , VGA - with adapter | API Supported | DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2 | Dimensions (WxDxH) | 24.1 cm x 11.115 cm | Manufacturer Warranty | 3-year warranty | Bundled with | EVGA Backplate |
General | |
CUDA Cores | 1344 |
Features | Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Nvidia SLI ready, TXAA, GPU Boost technology, FXAA, SMX technology, NVIDIA Adaptive Vertical Sync |
Memory | |
Size | 4 GB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 6.008 GHz |
Bus Width | 256-bit |
Bandwidth | 192.26 GBps |
System Requirements | |
OS Required | Microsoft Windows Vista / XP / 7, Microsoft Windows Vista / XP / 7 (64-bit versions) |
Required Power Supply | 500 W |
Additional Requirements | Two 6-pin power connectors |
Miscellaneous | |
Included Accessories | EVGA Accessory Pack |
Cables Included | 1 x DVI-VGA adapter |
Software Included | Drivers & Utilities, EVGA Precision X, EVGA OC Scanner X |
Depth | 24.1 cm |
Height | 11.115 cm |
Weight | 1.36 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
The following resources are available for the EVGA GeForce GTX 670 967MHz 4GB PCI-Express 3.0 HDMI Superclocked+ w/Backplate
