Turbocharge your experience with the powerful performance of the EVGA GeForce GTX 650 Ti and enjoy the latest games in full 1080P HD with this next-generation NVIDIA Kepler architecture-based GPU.
Performance
Resolution & Refresh
Operating System Support
Requirements
Product Description | EVGA GeForce GTX 650 Ti SSC - graphics card - GF GTX 650 Ti - 1 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | NVIDIA GeForce GTX 650 Ti | Memory | 1 GB GDDR5 | Core Clock | 1071 MHz | CUDA Cores | 768 | Effective Memory Clock | 5.4 GHz | Memory Interface | 128-bit | Max Resolution | 2560 x 1600 | Max Resolution Details | DVI: 2560 x 1600 / VGA: 2048 x 1536 | Max Monitors Supported | 3 | Interfaces | VGA - with adapter , Mini-HDMI , DVI-D (dual link) , DVI-I (dual link) | API Supported | DirectX 11, OpenCL, DirectCompute 5.0, OpenGL 4.2 | Dimensions (WxDxH) | 15.24 cm x 11.115 cm | Manufacturer Warranty | 3-year warranty |
General | |
CUDA Cores | 768 |
Features | Nvidia CUDA technology, Nvidia PureVideo HD technology, Nvidia PhysX-Ready, Nvidia 3D Vision technology, Nvidia Surround technology, Deep Color technology, Blu-Ray 3D Support, TXAA, NVIDIA Adaptive Vertical Sync, Nvidia Fast Approximate Antialiasing Technology (FXAA), Kepler GPU Architecture, Nvidia SMX Engine |
Memory | |
Size | 1 GB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 5.4 GHz |
Bus Width | 128-bit |
Bandwidth | 86.4 GBps |
System Requirements | |
OS Required | Microsoft Windows Vista / XP / 7, Windows 8 (32/64 bits) |
Required Power Supply | 400 W |
Additional Requirements | 6 pin PCI Express power connector |
Miscellaneous | |
Included Accessories | EVGA Accessory Pack, 6 pin PCIe power cable |
Cables Included | 1 x DVI-VGA adapter |
Software Included | Drivers & Utilities |
Depth | 15.24 cm |
Height | 11.115 cm |
Weight | 1.36 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
