Epson EB-U04 Projector Mobile/Nogaming WUXGA 1920 x 1200 Full HD
Key features
  • 3LCD technology and equally high White and Colour Light Output
  • Deep, rich blacks and dense shadow areas
  • Screen size of up to 300 inches
  • Lamp and filter life of 10,000 hours
  • Project from different sources with 2xHDMI inputs and mobile connectivity
Product codes
chevron icon
chevron icon
15 years worth of entertainment
With a long lamp and filter life, even if using the projector to watch a movie every day, it would be up to 15 years before either would need to be changed .
High-quality, bright images
Experience Full HD images that are three times brighter than competitor products thanks to 3LCD technology and equally high White and Colour Light Output. View your content like never before and pick out even the finest detail with crisp, clear blacks creating clearly defined shadows, all thanks to a 15,000:1 contrast ratio.
The big picture
Able to take content from a range of sources and display it up to a massive 300 inches, the EB-U04 has two HDMI inputs to allow users to broadcast Full HD digital video and audio content. You can even project photos and documents straight from a smartphone or tablet with Epson's iProjection app .
Everything included for fuss-free installation
An included carry case makes for easy movement of the projector from room to room. Horizontal and vertical keystone correction mean the projector can be installed in a number of places without distorting the image.
Eco-friendly features
By varying the lamp power according to what content is being displayed, the EB-U04 can help save energy, while eco-mode helps reduce power consumption and extend lamp life.
chevron icon
Product Description Epson EB-U04 - 3LCD projector - portable
Device Type 3LCD projector - 1080p
Brightness (White) 3000 lumens
Brightness (Colour) 3000 lumens
Contrast Ratio 15000:1 (dynamic)
Resolution WUXGA (1920 x 1200)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Bulb type 200 Watt
Bulb life cycle Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input RGB, S-Video, composite video
Speakers Speaker(s) - integrated
Power AC 120/230 V (50 - 60 Hz)
Power Consumption Operational 277 Watt
Dimensions (WxDxH) 29.7 cm x 24.4 cm x 7.7 cm
Weight 2.6 kg
chevron icon
Accessories
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
