Make presentations more effective
The EB-925 useful features can make presentations more effective. The powerful 16W integrated speaker helps your audience hear clearly, and there's a handy microphone input. Share 3D objects on the big screen by connecting to Epson's ELP-DC06 document camera. You can also share pictures with your audience by projecting directly from your USB drive, camera or portable hard drive using the EasyMP slideshow feature.
Hassle-free installation
Whatever your room layout, installing the EB-925 is straightforward. Even if the projector is at an angle to the screen, you can quickly align the picture using automatic vertical and manual horizontal keystone correction, and the x1.6 optical zoom adds further flexibility. For easy desktop use, the projector's pull-out foot supports a tilt angle of up to 16 degrees.
Easy control and maintenance
Easily control and monitor your projector fleet using Epson's EasyMP advanced networking features. Broadcast image and sound over your network via the LAN input. Save time and hassle by adjusting settings, such as projector on/off times, from a single point on your network. And remove the need for physical checks and free up your IT staff by setting up automatic email alerts for temperature and lamp status.
Wide connectivity
The EB-925 has plenty of connectivity options to suit your needs, including an HDMI input. Connect to your wireless network and present instantly with the optional wireless module and quick wireless connection key. A single USB cable is all that's needed to connect your laptop to the projector thanks to 3-in-1 USB display.
Low TCO
Helping ease demands on your budget, the EB-925 has a low total cost of ownership resulting from its long lamp life of 6,000 hours (in eco mode) and improved dust filter for a longer maintenance cycle of up to 5,000 hours.
Product Description | Epson EB-925 - 3LCD projector - LAN | Device Type | 3LCD projector | Built-in Devices | Speaker | Brightness | 3000 lumens | Brightness (Colour) | 3500 lumens | Contrast Ratio | 2000:1 | Resolution | XGA (1024 x 768) | Native Aspect Ratio | 4:3 | Bulb type | E-TORL UHE 230 Watt | Bulb life cycle | Up to 4000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode | Video Input | RGB, S-Video, composite video, component video LAN | Digital Video Standard | High-Definition Multimedia Interface (HDMI) | Video Modes | 1080p | Video Output | RGB | Speakers | Speaker(s) - integrated | Dimensions (WxDxH) | 34.5 cm x 26.3 cm x 9.3 cm | Weight | 3.4 kg | Manufacturer Warranty | 3-year warranty |
General | |
Projector | |
Brightness (Reduced) | 2450 lumens |
Image Size | 76 cm - 762 cm |
Throw Ratio | 1.38 - 2.24:1 |
Resolution | XGA - XGA (1024 x 768) |
Features | EPSON 3LCD technology |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.51-1.99 |
Zoom Type | Manual |
Zoom Factor | 1.6x |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -30 / +30 |
Horizontal Keystone Correction | -30 / +30 |
Video Input | |
Analogue video Signal | RGB, S-Video, composite video, component video |
Video Interfaces | VGA, HDMI, composite video, S-Video |
LAN and Wireless Image Transferring Protocols | Wired LAN |
Video Output | |
Analogue Video Signal | RGB |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Speakers | 1 x mixed channel |
Input Device | |
Type | External |
Expansion / Connectivity | |
Interfaces | 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 2 x audio line-in - RCA , 1 x USB - 4 pin USB Type B , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x microphone - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A |
Miscellaneous | |
Included Accessories | Wireless remote control |
Cables Included | 1 x VGA cable |
Security Features | Security lock slot (cable lock sold separately), password protection |
Dimensions & Weight | |
Width | 34.5 cm |
Depth | 26.3 cm |
Height | 9.3 cm |
Weight | 3.4 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years , Limited warranty - lamp - 1 year |
Environmental Parameters | |
Sound Emission | 37 dB |
Sound Emission (Economic Mode) | 29 dB |
