Bring interactivity to any meeting room with our latest ultra-short-throw projector, featuring finger-touch and dual pen capability, a high brightness level of 4,400 lumens, Full HD WUXGA resolution and remote multi-location connectivity. The ultra-short-throw EB-1460Ui is designed to present a scalable screen size of up to 100 inches to deliver the requirements of any business working environment.
Up to 100-inch display and outstanding quality
Full HD WUXGA resolution combined with Epson’s 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity also means that the audience benefits from sharper and clearer content displayed in any meeting room environment.
All in one office solution
This interactive meeting room solution combines the benefits of flipcharts, whiteboards and conventional screens into one unified meeting room solution. Meeting participants can view and annotate whiteboard content from a range of smart devices, without the need for any special application and this ensures information remains secure with the ability to apply passwords to meetings and notes.
Finger-touch and dual pen
Use your fingers to annotate directly on the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, colleagues can work simultaneously using different pen attributes.
Sliding split screen
Combine two sources and project, such as multi-source video conference and presentation, to optimise interaction.
Wireless & Screen Mirroring connectivity
Share content easily from a range of smart devices using the iProjection App and screen mirroring feature. The same content can be annotated remotely, with up to four networked projection systems connected at the same time.
Product Description | Epson EB-1460Ui - 3LCD projector - 802.11b/g/n wireless / LAN / Miracast - white | Device Type | 3LCD projector - 1080p | Colour | White | Built-in Devices | Speaker | Brightness (White) | 4400 lumens | Brightness (Colour) | 4400 lumens | Contrast Ratio | 300:1 / 16000:1 (dynamic) | Resolution | WUXGA (1920 x 1200) | Native Aspect Ratio | 16:10 | Colour Support | 1.07 billion colours | Video Input | RGB, S-Video IEEE 802.11b/g/n wireless / LAN / Miracast | Speakers | Speaker(s) - integrated | Power | AC 230V (50 - 60 Hz) | Power Consumption Operational | 490 Watt | Dimensions (WxDxH) | 47.4 cm x 44.7 cm x 13 cm | Weight | 8.5 kg | Manufacturer Warranty | 3-year warranty |
General | |
Networking | 802.11b/g/n, Ethernet |
Enclosure Colour | White |
Projector | |
Brightness (Reduced) | 2700 lumens |
Image Size | 178 cm - 254 cm |
Projection Distance | 0.4 m - 0.6 m |
Throw Ratio | 0.27 - 0.37:1 |
Digital Zoom Factor | 1.35x |
Resolution | WUXGA - WUXGA (1920 x 1200) |
Features | sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode, Auto Calibration |
Lens | |
Focus Type | Manual |
Lens Aperture | F/1.6 |
Keystone Correction Direction | Horizontal, vertical |
Vertical Keystone Correction | -3 / +3 |
Horizontal Keystone Correction | -3 / +3 |
Video Input | |
Analogue video Signal | RGB, S-Video |
Video Interfaces | VGA, HDMI, S-Video, MHL |
LAN and Wireless Image Transferring Protocols | IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, Miracast |
Speakers | |
Type | Integrated |
Sound Output Mode | Mono |
Output Power / Channel | 16 Watt |
Speakers | 1 x mixed channel |
Expansion / Connectivity | |
Interfaces | 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out , 1 x DVI-D output |
Miscellaneous | |
Included Accessories | Wireless remote control, control pad, pen case, finger touch unit, interactive pens |
Cables Included | 1 x USB cable |
Mounting Kit | Included |
Security Features | Security lock slot (cable lock sold separately), password protection |
Power | |
Power Source | AC |
Voltage Required | AC 230V (50 - 60 Hz) |
Power Consumption Stand by | 0.5 Watt |
Software / System Requirements | |
Software Included | Epson Easy Interactive Tools, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection |
Dimensions & Weight | |
Width | 47.4 cm |
Depth | 44.7 cm |
Height | 13 cm |
Weight | 8.5 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
Sound Emission | 38 dBA |
Sound Emission (Economic Mode) | 30 dBA |
