BT.com
Wishlist
Edimax N150 Wireless Fast Ethernet Router
Delivery
Standard Due date unavailable
The BR-6228nS V3 is a 150Mbps 5-in-1 multi-function Wi-Fi solution which supports IEEE 802.11b/g/n standards and provides significantly improved coverage with the High-gain antenna. Operating as a router, access point, range extender, Wi-Fi Bridge or WISP, the BR-6228nS V3's flexibility meets the demands of any networking applications. The smart iQ Setup wizard makes setup and installation as easy as a few clicks. Impressive performance and a competitive price make the BR-6228nS V3 a cost-effective solution for home or small office environments.
Edimax BR-6228nS V3 - wireless router - 802.11b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Data Transfer Rate
150 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, DDNS
Routing Protocol
Static IP routing
Firewall protection, DMZ port, DHCP support, NAT support, NAPT support, Stateful Packet Inspection (SPI), DoS attack prevention, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, firmware upgradable, WISP mode, Quality of Service (QoS), virtual server support, Wi-Fi Protected Setup (WPS), IPSec passthrough, reset button
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, UPnP
19 cm x 16.2 cm x 4.2 cm
230 g
Enclosure Type
Desktop
Wireless, wired
Data Transfer Rate
150 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi Protected Setup, UPnP, BSMI, FCC, NCC
RAM
32 MB SDRAM
Flash Memory
4 MB
Status Indicators
Power, WAN, wireless, link/activity, Internet
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
1
External power adapter
1 x network cable
Software Included
Drivers & Utilities
19 cm
16.2 cm
4.2 cm
230 g
45 °C
10 - 90% (non-condensing)
Scroll to top
