The Duracell range of mobile phone power accessories provide superior quality performance in a superbly designed charger. As you would expect from such a trusted name as Duracell.
Product Description | Duracell DMAC11-UK power adapter - Lightning | Product Type | Power adapter | Dimensions (WxDxH) | 11 cm x 8 cm x 5.6 cm | Weight | 80 g | Colour | Black | Localisation | United Kingdom | Output Connector Type | Lightning | Voltage Required | AC 110-240 V | Voltage Provided | 5 V | Cables | Lightning cable - 1 m | Manufacturer Warranty | 3-year warranty |
General | |
Designed For | Portable player, tablet, mobile phone |
Width | 11 cm |
Depth | 8 cm |
Height | 5.6 cm |
Weight | 80 g |
Enclosure Colour | Black |
Power Device | |
Input Connectors | Power |
Output connectors | Apple Lightning |
Miscellaneous | |
Cables Included | Lightning cable - 1 m |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
