The Duracell compact battery charger is a fantastic product that can fully charge your camera and camcorder battery in under 2 hours. The charger is supplied with a mains wall adapter for use around the home.
This charger has an LED light which indicates the status of a charge at any time as well as in built safety features meaning it will never over charge your battery. The charger is compatible with the popular camera and camcorder batteries.
Product Description | Duracell DR5700EF-UK battery charger | Product Type | Battery charger | Localisation | United Kingdom | Voltage Required | AC 230 V | Manufacturer Warranty | 3-year warranty | Designed For | Sony InfoLithium G-type NP-BG1; InfoLithium H Series NP-FH50, NP-FH50AM, NP-FH70; InfoLithium K-type NP-BK1; InfoLithium L Series NP-F550; NP-BG1, F330, F550, FH50; NPF-330 |
General | |
Designed For | Camcorder, camera |
Power Device | |
Features | LED indicator |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Compatibility Information | |
Designed For | Sony InfoLithium G-type NP-BG1 , Sony InfoLithium H Series NP-FH50, NP-FH50AM, NP-FH70 , Sony InfoLithium K-type NP-BK1 , Sony InfoLithium L Series NP-F550 , Sony NP-BG1, F330, F550, FH50 , Sony NPF-330 |
