Marketing description is not available.
Product Description | Duracell DRC827 battery - Li-Ion | Product Type | Battery | Dimensions (WxDxH) | 4 cm x 3.1 cm x 5.9 cm | Weight | 118 g | Battery | Lithium Ion - 2700 mAh | Manufacturer Warranty | 3-year warranty | Designed For | Canon XA10; iVIS HF G10, HF S10, HF11; LEGRIA HF G10, HF M300, HF M306, HF M31, HF M32, HF M36, HF M41, HF S10, HF S100, HF S11, HF S20, HF S200, HF S21, HF20, HF200, HF21; VIXIA HF G10, HF M30, HF M300, HF M31, HF M32, HF M40, HF M400, HF M41, HF S10, HF S11, HF S20, HF S200, HF S21, HF200, HF21 |
General | |
Designed For | Camcorder |
Width | 4 cm |
Depth | 3.1 cm |
Height | 5.9 cm |
Weight | 118 g |
Battery | |
Technology | Lithium Ion |
Voltage Provided | 7.4 V |
Capacity | 2700 mAh |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Compatibility Information | |
Designed For | Canon HF11, HG20, HG21, XA10 , Canon iVIS HF G10, HF S10, HF11 , Canon LEGRIA HF G10, HF M300, HF M306, HF M31, HF M32, HF M36, HF M41, HF S10, HF S100, HF S11, HF S20, HF S200, HF S21, HF20, HF200, HF21 , Canon VIXIA HF G10, HF M30, HF M300, HF M31, HF M32, HF M40, HF M400, HF M41, HF S10, HF S100, HF S11, HF S20, HF S200, HF S21, HF11, HF20, HF200, HF21, HG20, HG21 |
