We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Draytek ANT-2520 is a dual-band indoor directional patch antenna. It is used for normal indoor point-to-point wireless connection applications. ANT-2520 is designed to connect with most wireless devices that use a detachable antenna. Simply unscrew the existing antenna on your device, connect to the Draytek high-gain antenna and enjoy the benefits of wireless network.
Product Description | Draytek ANT-2520 - antenna | Product Type | Antenna | Dimensions (WxDxH) | 6.5 cm x 1.8 cm x 16.5 cm | Colour | Black | Form Factor | Plate | Intended For | Wi-Fi | Aerial Placing / Mounting | Indoor | Compatibility | 802.11 a/b/g/n/ac | Frequency Range | 2.4 - 2.5 GHz, 5.15 - 5.85 GHz | Gain | 10 dBi (for 5 GHz), 7.5 dBi (for 2.4 GHz) | Directivity | Directional | Manufacturer Warranty | 1-year warranty |
General | |
Width | 6.5 cm |
Depth | 1.8 cm |
Height | 16.5 cm |
Enclosure Colour | Black |
Aerial | |
Voltage Standing Wave Ratio (VSWR) | 2.0:1 |
Horizontal Beamwidth | 70° (at 2.4 GHz), 60° (at 5 Ghz) |
Vertical Beamwidth | 60° (at 2.4 GHz), 30° (at 5 Ghz) |
Cabling & Wiring | |
Connector Provided | 1 x RP-SMA male |
Miscellaneous | |
Features | MIMO technology |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
