The Automatic Panorama mode makes shooting 360° panoramas easier than ever. Just hold the Osmo up above your head and tap the shutter button. The camera will rotate, capturing images as it goes while staying completely level. Don't just get a snapshot of a piece of your travels. Make a memory of the whole scene.
Product Description | DJI Osmo - action camera | Product Type | Action camera - 4K | Action Camera Type | Mountable | Memory Card Slot | microSD card | Wireless Interface | Wireless LAN | Sensor Resolution | 12.76 MP | Effective Sensor Resolution | Photo: 12.4 MP | Max Video Resolution | 4096 x 2160 | Lens System | F/2.8 | Supported Battery | Li-Polymer rechargeable battery - 900 mAh (included) | Dimensions (WxDxH) | 16.15 cm x 4.82 cm x 6.18 cm | Weight | 201 g |
General | |
Camcorder Sensor Resolution | 12.76 MP |
Sensor Qty | 1 CMOS |
Effective Photo Resolution | 12.4 MP |
Widescreen Video Capture | Yes |
Optical Sensor Type | Exmor R CMOS |
Optical Sensor Size | 1/2.3" |
Frame Rate (Max Resolution) | 25 fps |
ISO (Max) | 3200 |
Digital Video Format | H.264, MOV, AVC |
Image Recording Format | JPEG, DNG (RAW) |
Connectivity Features | Remote control via mobile devices, remote live view |
Exposure & White Balance | |
Light Sensitivity | ISO 100-1600, ISO 100-3200 |
Exposure Modes | Automatic |
White Balance | Automatic |
Max Shutter Speed | 1/8000 sec |
Min Shutter Speed | 8 sec |
Auto Exposure Bracketing | 3, 5 steps in 2/3 EV step |
Lens System | |
Type | F/2.8 |
Focal Length Equivalent to 35mm Camera | 20mm |
Max View Angle | 94 degree(s) |
Additional Features | |
Additional Features | Multi-picture burst |
Action Camera Features | |
Features | Time-Lapse recording |
Miscellaneous | |
Included Accessories | Lens cap, 3-axis gimbal |
Body Material | Magnesium alloy |
Battery | |
Battery Type | Lithium polymer - manufacturer-specific |
Details | Li-Polymer rechargeable battery - 900 mAh (included) |
Battery Life Details | Video recording - 1 hour |
Memory / Storage | |
Supported Memory Cards | microSD Card, microSDHC Card, microSDXC Card, microSDHC UHS-I Memory Card, microSDXC UHS-I Card |
Memory Card | 16 GB microSDHC |
Memory Card Included | Yes |
Memory Card Max Supported Size | 64 GB |
Image Storage | 4000 x 3000 |
Video Capture | 4096 x 2160 - 25 fps , 4096 x 2160 - 24 fps , 3840 x 2160 - 25 fps , 3840 x 2160 - 24 fps , 3840 x 2160 - 30 fps , 2704 x 1520 - 30 fps , 2704 x 1520 - 25 fps , 2704 x 1520 - 24 fps , 1920 x 1080 - 120 fps , 1920 x 1080 - 60 fps , 1920 x 1080 - 50 fps , 1920 x 1080 - 48 fps , 1920 x 1080 - 30 fps , 1920 x 1080 - 25 fps , 1920 x 1080 - 24 fps , 1280 x 720 - 60 fps , 1280 x 720 - 50 fps , 1280 x 720 - 48 fps , 1280 x 720 - 30 fps , 1280 x 720 - 25 fps , 1280 x 720 - 24 fps |
Dimensions & Weight | |
Width | 16.15 cm |
Depth | 4.82 cm |
Height | 6.18 cm |
Weight | 201 g |
