Marketing description is not available.
Product Description | DJI Phantom Series Multifunctional Backpack - rucksack for drone | Product Type | Rucksack for drone | Screen Size Compatibility | 15" | Dimensions (WxDxH) | 33 cm x 21 cm x 53 cm | Weight | 2.5 kg | Material | Nylon, PC/ABS | Colour | Grey, black | Designed For | Phantom 4, 4 Advanced, 4 Advanced+, 4 Pro, 4 Pro+ |
General | |
Width | 33 cm |
Depth | 21 cm |
Height | 53 cm |
Weight | 2.5 kg |
Lining Material | DTY twill polyurethane |
Carrying Case | |
Type | Rucksack |
Recommended Use | For drone |
Protection | Waterproof |
Carrying Strap | Shoulder carrying straps, top carry handle |
Closure Type | Zipper, 2x zipper pockets |
Additional Compartments | Notebook, remote control, 3 x batteries, 12 x propellers |
Maximum Weight Capacity | 12.5 kg |
Compatibility Information | |
Designed For | DJI Phantom 4, 4 Advanced, 4 Advanced+, 4 Pro, 4 Pro+ |
