Wyse Z90D7 is a super high-performance thin client for virtual desktop environments. Featuring a revolutionary, unified engine that eliminates performance constraints, the Z90D7 achieves incredible speed and power for the most demanding applications, rich graphics and HD video. Take a unit from box to productivity in minutes. The Z90D7 is an ideal thin client for the most demanding mix of virtual desktop or cloud applications.
Product Description | Dell Wyse Z90D7 Thin Client - DTS - G-T56N 1.65 GHz - 4 GB - flash 16 GB | Type | Thin client - desktop slimline | Processor | 1 x AMD G-T56N 1.65 GHz (Dual-Core) | RAM | 4 GB DDR3 SDRAM | Hard Drive | Flash 16 GB | Optical Storage | No optical drive | Graphics Controller | AMD Radeon HD 6320 | Audio Output | Stereo - integrated | Networking | GigE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Microsoft Windows Embedded Standard 7 | Dimensions (WxDxH) | 4.7 cm x 22.5 cm x 20 cm | Weight | 1.12 kg | Environmental Standards | ENERGY STAR Qualified EPEAT Silver | Manufacturer Warranty | Limited warranty - 3 years |
General | |
Type | Thin client |
Product Form Factor | Desktop slimline |
Built-in Devices | Speaker |
Processor / Chipset | |
CPU | AMD G-T56N |
Clock Speed | 1.65 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
RAM | |
Installed Size | 4 GB |
Technology | DDR3 SDRAM |
Hard Drive | |
Type | Flash |
Capacity | 16 GB |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Type | Integrated |
Graphics Processor | AMD Radeon HD 6320 |
Video Interfaces | VGA, DVI, DisplayPort |
Audio Output | |
Type | Integrated |
Sound Output Mode | Stereo |
Max Sampling Rate | 48 kHz |
Networking | |
Type | Integrated |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Interfaces | 1 x DisplayPort , 1 x DVI-I , 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out (1 in front) , 1 x microphone (1 in front) , 2 x serial , 1 x parallel , 1 x PS/2 keyboard |
Miscellaneous | |
Included Accessories | Vertical stand |
Cables Included | DVI-VGA adapter |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Compliant Standards | FCC Class B certified, TUV GS, VCCI, C-Tick, ISO 9241-3, ISO 9241-8, EN 60950, UL 60950, RoHS, WEEE |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Operating System / Software | |
Sustainability Information | |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight | |
Width | 4.7 cm |
Depth | 22.5 cm |
Height | 20 cm |
Weight | 1.12 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 95% (non-condensing) |
