Dell Wyse Thin Client Desktop 3000 Series - Strong Desktop Performance on a Budget. Simplified performance. Efficient, easy-to-use thin clients for cost-effective virtual desktop sites.
Product Description | Dell Wyse 3020 - DTS - ARMADA PXA2128 1.2 GHz - 2 GB - flash 4 GB | Type | Thin client - desktop slimline | Bundled Services | 3 Years Dell Collect and Return Service | Processor | 1 x Marvell ARMADA PXA2128 / 1.2 GHz (Dual-Core) | RAM | 2 GB DDR3 SDRAM | Hard Drive | Flash 4 GB | Optical Storage | No optical drive | Audio Output | Stereo | Networking | GigE | Power | AC 120/230 V (50/60 Hz) | OS Provided | Wyse Thin OS | Colour | Black | Dimensions (WxDxH) | 17.6 cm x 12.1 cm x 3.5 cm | Weight | 500 g | Pricing Type | Build To Stock (BTS) | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 3 years |
General | |
Type | Thin client |
Product Form Factor | Desktop slimline |
Colour | Black |
Processor / Chipset | |
CPU | Marvell ARMADA PXA2128 |
Clock Speed | 1.2 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
RAM | |
Installed Size | 2 GB |
Technology | DDR3 SDRAM |
Hard Drive | |
Type | Flash |
Capacity | 1 x 4 GB |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Video Interfaces | DVI |
Max Monitors Supported | 2 |
Audio Output | |
Sound Output Mode | Stereo |
Max Sampling Rate | 48 kHz |
Input Device | |
Type | Mouse (on selected markets only) |
Mouse | |
Technology | Optical |
Interface | USB |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Interfaces | 1 x DVI-I , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-out , 1 x DVI-D |
Miscellaneous | |
Included Accessories | Horizontal feet |
Cables Included | DVI-VGA adapter |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Compliant Standards | RoHS, WEEE |
Power | |
Device Type | Power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 30 Watt |
Power Consumption Operational | 10 Watt |
Operating System / Software | |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight | |
Width | 17.6 cm |
Depth | 12.1 cm |
Height | 3.5 cm |
Weight | 500 g |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 95% (non-condensing) |
